CAPSMAN shows device with MAC adress
Hello
I have recently added a new RBMAPL-2ND device into my CAPSMAN setup and for some reason it is recognized but shows up with it’s MAC address, not IP.
It did get a DHCP IP on the ETH port, I can ping it but can not connect to it using Winbox (or SSH but did not turn it on anyway).
What might I have missed ?
http://forum.mikrotik.com/t/2-capsmans-on-the-network/164650/7
Reset the device to CAPS mode.
using the reset button or Winbox/System/Reset Configuration/ CAPS Mode
Or disable all firewall rules.
