I notice something when I use “create-dynamic-enabled” for 5ghz AC interfaces. 5ghz AC interfaces go up significantly slower than 2.4ghz N
Is that a normal or I miss something?
HEX is used for capsman and I have 2 cap (wAP AC and CAP AC)
# jul/14/2020 23:10:24 by RouterOS 6.47.1
# software id = 3ZHC-8LEP
# model = RouterBOARD 750G r3
# serial number = 6F3807133B3B
/caps-man channel
add band=2ghz-onlyn control-channel-width=20mhz extension-channel=XX name=n tx-power=2
add band=5ghz-onlyac name=ac tx-power=2
/caps-man datapath
add bridge=lan name=lan-br
add bridge=vlan66-br client-to-client-forwarding=no local-forwarding=no name=vlan66 vlan-id=66 vlan-mode=use-tag
/caps-man security
add authentication-types=wpa-psk,wpa2-psk encryption=aes-ccm name=**** passphrase=****
add authentication-types=wpa-psk,wpa2-psk encryption=aes-ccm name=vlan66 passphrase=****
/caps-man configuration
add channel=n country=bulgaria datapath=lan-br distance=indoors installation=indoor mode=ap name=n security=**** ssid=****_n
add channel=ac country=bulgaria datapath=lan-br distance=indoors installation=indoor mode=ap name=ac rates.vht-supported-mcs="" security=**** ssid=****_ac
add channel=n country=bulgaria datapath=lan-br distance=indoors installation=indoor mode=ap name=n_sys security=**** ssid=****_sys
add channel=n country=bulgaria datapath=vlan66 hide-ssid=yes installation=indoor name=vlan66 security=vlan66 ssid=isolated
/caps-man access-list
add action=reject allow-signal-out-of-range=10s client-to-client-forwarding=no disabled=no signal-range=-120..-65 ssid-regexp=*****
add action=accept allow-signal-out-of-range=10s disabled=no mac-address=28:ED:E0:B2:CB:B3 ssid-regexp=****
add action=reject allow-signal-out-of-range=10s disabled=no ssid-regexp=****
/caps-man manager
set ca-certificate=ca certificate=auto enabled=yes
/caps-man provisioning
add action=create-dynamic-enabled master-configuration=ac name-format=identity radio-mac=64:D1:54:A6:C6:29
add action=create-dynamic-enabled master-configuration=n name-format=identity radio-mac=64:D1:54:A6:C6:2A slave-configurations=n_sys,vlan66
add action=create-dynamic-enabled master-configuration=n name-format=identity radio-mac=74:4D:28:65:68:52 slave-configurations=n_sys,vlan66
add action=create-dynamic-enabled master-configuration=ac name-format=identity radio-mac=74:4D:28:65:68:53
