Capsman SNMP and WLAN Speed
Hi
i have 2 thinks i need to ask
But first some Informations
Iam Using Capsman on a Virtual Server with around 170 CAPs
We had help by setting up and configure the Server with APs but now we run into a view problems and cant ask the person again
Maybe the easiest part on my problem
I need SNMP Activated on each CAP with community public
Is it possible to push the needed commands to the CAPS via Capsman?
/snmp set enabled=yes
And how to set Communityname if not public? somethimes it seems to be some other name
The Second is maybe a bit harder
Its about Wireless Speed in 2400hz Netzwork
5Ghz is blazing fast
In 2400 i get about 1-2mbit upd and download on a 100mbit Internet Network
My Settings are
Band 2ghz-b/g/n
Channel Ce
MTU 1500
L2 MTU 1600
ARP enabled
Channel Width 20MHz
