CAPSMAN: SSID is not visible
i have three cAP ac (RBcAPGi-5acD2nD) devices in my home network. I want to set one device as a CAPSMAN Manager to control the wireless network.
The network should have one SSID and 2G and 5G on the same SSID.
My configuration of the CAPSMAN Manager device is the following:
[admin@MikroTik_DG] /caps-man> export
# oct/16/2022 16:28:50 by RouterOS 6.49.7
# software id = R5KY-5HLG
# model = RBcAPGi-5acD2nD
# serial number =
/caps-man channel
add control-channel-width=20mhz extension-channel=disabled frequency="" name=\
    5g-5660-5180 skip-dfs-channels=no
add control-channel-width=20mhz extension-channel=disabled frequency=\
    2412,2432,2452,2472 name=2g-1-5-9-13
/caps-man security
add authentication-types=wpa2-psk encryption=aes-ccm group-encryption=aes-ccm \
    name=wlan passphrase=
/caps-man configuration
add channel=5g-5660-5180 country=germany installation=indoor mode=ap name=\
    cfg-5GHz security=wlan ssid=wlan
add channel=2g-1-5-9-13 channel.band=2ghz-g/n country=germany installation=\
    indoor mode=ap name=cfg-2GHz security=wlan ssid=wlan
/caps-man manager
set enabled=yes
/caps-man manager interface
set [ find default=yes ] forbid=yes
add disabled=no interface=local
add interface=local
add disabled=no interface=ether1
/caps-man provisioning
add action=create-dynamic-enabled hw-supported-modes=g,gn identity-regexp=AP \
    master-configuration=cfg-2GHz name-format=identity
add action=create-dynamic-enabled hw-supported-modes=a,ac,an identity-regexp=AP \
    master-configuration=cfg-5GHz name-format=identity
The clients are setup correctly, but it seems, that there is no config attached to the clients. The SSID is empty with no security.
What i am doing wrong? After several days of trying different configurations, i was not able to find a solution.
BW Maximilian
