Does CAPsMAN support superchannel frequencies?
I think you should be able to manually add a frequency and just enter the supper channel ones you are planning to use
I just tried with CAPSMAN 2 and ROS v6.44 - if you do so, there is “unsupported channel” message" with CAPSMAN 2.
I know it’s an old thread, just I could not find solution elsewhere.
