I got bad result of capsman wifi controller .
How to fix this issue ., please advice
speed test running around 10Mb/s ., need to know how to improve speed for Capsman.
Thanks.
Thanks.
as the mikrotik says "CAPsMAN v2 ready for testing "
back to wireless-fp
Are you sure that it’s package version?
From your post, I see that you have problem with tx from the AP only. RX is OK. Maybe lowering the tx-power parameter will help you?
