Hi guys, i want to report an issue with the capsman upgrade policy.
I am running a ROS 6.37rc12 but this bug exists since the cap upgrade setting was introduced.
Bug description:
When using 'require same version ’ then caps act like having the 'suggest same version ’ setting set,- and vice versa…
Example:
With require same version i get a log entry: upgrade failed, Provision as same version only suggested.
But It should be the other way around. Thanks for your great work. Keep it going…
