Capsman v2 and vap bridging Question
I have a total of 14 AP’s in our House, all AP’s serving between 2-4 SSID’s on differents Subnets/Vlans.
Now I tried capsman v2 on 2 AP’s, and the Router is the Capsman Manager.
So far so good, the only Question I have is that currently I set the SSID’s in Capsman,
then connect the Caps to the Manager, assign the SSID’s to the Caps, and to get proper Routing, I will have to set each AP & each SSID to the correct Bridge in the Capsmanager. Is that correct?
I originally thought that I would select the vlan / Bridge for a single SSID once, and assign that SSID to the Caps.
So I would have one Bridgeport / SSID.
Currently, if I wil be using all my 14 AP’s with Capsmanager, I would have to add every SSID manually to the Brideport/vlan .
Can it be done differnetly?
