I have one RB2011 and one HAP.
CAPsMAN is running on RB2011 and both router are configured to use cap
Everything is good when the client is using the HAP AP, but when using rb2011 I they can’t receive an IP Address.
on log I can see:
mac address@cap3 connected
mac address@cap3 disconnected, received deauth: sending station leaving (3.)
in a continual loop.
I used this tutorial to configure everything.
https://www.youtube.com/watch?v=xVTsa59ijD4
have no clue what is wrong.
Thanks for your help
Please provide your configuration for /int bridge , /caps datapath and /caps config on your RB2011
If your clients aren’t able to get an IP-address on the RB2011 the local bridge might not bound to the wifi interface
Thanks for the help
Edit: I’m currently connected to the HAP radio witch is cap1 interface. when i roam on the rb2011 witch is cap3 interface I receive the cap3 connected / cap3 disconnected receive deauth : sending station leaving(3).
The device won’t return to the other radio until i disconnect and reconnect has they are currently both reachable from anywhere in the house.
0 R ;;; BRIDGE PRIVATE
name="BR_PRIVATE" mtu=1500 actual-mtu=1500 l2mtu=1594 arp=enabled
mac-address=4C:5E:0C:32:DF:6A protocol-mode=rstp priority=0x8000
auto-mac=no admin-mac=4C:5E:0C:32:DF:6A max-message-age=20s
forward-delay=15s transmit-hold-count=6 ageing-time=5m
1 R ;;; BRIDGE PRIVATE2
name="BR_PRIVATE2" mtu=1500 actual-mtu=1500 l2mtu=1594 arp=enabled
mac-address=4C:5E:0C:32:DF:6C protocol-mode=none priority=0x8000
auto-mac=yes admin-mac=00:00:00:00:00:00 max-message-age=20s
2 R ;;; BRIDGE PUBLIC
name="BR_PUBLIC" mtu=1500 actual-mtu=1500 l2mtu=1594 arp=enabled
/caps datapath
I have nothing
/CAPS config
0 name="cfg1" mode=ap ssid="test1" country=no_country_set
security=test1 security.authentication-types=wpa-psk,wpa2-psk
security.passphrase="12we45qw" channel.frequency=2462 channel.width=20
channel.band=2ghz-b/g/n
I think your wireless caps-interfaces don’t have a IP-connection because datapath is missing. Wether you enable local forwarding or forwarding to the bridges you created on caps manager:
vitesse:
/caps datapath
I have nothing
You should add:
/caps datapath add bridge=BR_PRIVATE local-forwarding=no name="BR_PRIVATE"
/caps datapath add bridge=BR_PRIVATE2 local-forwarding=no name="BR_PRIVATE2"
and then to your config:
Please add:
/caps config set datapath=BR_PRIVATE
