Hi Guys,
I have a problem using CAPsMAN with multiple VLANs.
I have 2 RB951G as CAPsMAN and CAP, 1 RB1100 as switch. Both CAPsMAN and CAP are configured to use CAP (CAPsMAN is CAP1 and the other is CAP2). everything is fine with CAP1. But when i enabled CAP2 my client can’t receive ip address.
CAPsMAN Bridge
0 R name="bridge1" mtu=auto actual-mtu=1500 l2mtu=1598 arp=enabled
mac-address=4C:5E:0C:D5:2F:25 protocol-mode=rstp priority=0x8000
auto-mac=yes admin-mac=00:00:00:00:00:00 max-message-age=20s
forward-delay=15s transmit-hold-count=6 ageing-time=5m
Bridge port
Flags: X - disabled, I - inactive, D - dynamic
# INTERFACE BRIDGE PRIORITY PATH-COST HORIZON
0 ether2 bridge1 0x80 10 none
1 I ether3 bridge1 0x80 10 none
2 I ether4 bridge1 0x80 10 none
3 I ether5 bridge1 0x80 10 none
4 wlan1 bridge1 0x80 10 none
VLAN
Flags: X - disabled, R - running, S - slave
# NAME MTU ARP VLAN-ID INTERFACE
0 R vlan10 1500 enabled 10 bridge1
1 R vlan20 1500 enabled 20 bridge1
2 R vlan30 1500 enabled 30 bridge1
3 R vlan40 1500 enabled 40 bridge1
wireless cap
enabled: no
interfaces: wlan1
certificate: none
lock-to-caps-man: no
discovery-interfaces: bridge1
caps-man-addresses: 192.168.1.29
caps-man-names:
caps-man-certificate-common-names:
bridge: none
CAP config
0 name="VLAN10" mode=ap ssid="ADTEK_GUEST" datapath=vlan10 channel=channel
1 name="VLAN20" mode=ap ssid="ADTEK_MGMT" security=vlan20 channel=channel
2 name="VLAN30" mode=ap ssid="ADTEK_HR" security=vlan30 channel=channel
3 name="VLAN40" mode=ap ssid="ADTEK_ADMIN" security=vlan40 channel=channel
CAP datapath
0 name="vlan10" bridge=bridge1 local-forwarding=yes vlan-mode=use-tag vlan-id=10
1 name="vlan20" client-to-client-forwarding=yes bridge=bridge1
local-forwarding=yes vlan-mode=use-tag vlan-id=20
2 name="vlan30" client-to-client-forwarding=yes bridge=bridge1
local-forwarding=yes vlan-mode=use-tag vlan-id=30
3 name="vlan40" client-to-client-forwarding=yes bridge=bridge1
local-forwarding=yes vlan-mode=use-tag vlan-id=40
Thanks in advance. And sorry for my bad english.
