CapsMAN v7.13 vlan + 2 ax caps
Hello
Easy config
x86 Mikroitk v7.13 with eth1, this device is CapsMAN. It have 3 vlan. It is connected to MAIN router over trunk port.
I have 2 cAP ax. 2 ssid for enployers (vlan10), and 1 for guest (vlan 254)
x86 Settup:
add admin-mac=00:23:24:D1:4C:DF auto-mac=no fast-forward=no name=bridge1
port-cost-mode=short vlan-filtering=yes
set [ find default-name=ether1 ] disable-running-check=no
/interface vlan
add interface=bridge1 name=vlan10 vlan-id=10
add interface=bridge1 name=vlan20 vlan-id=20
add interface=bridge1 name=vlan254 vlan-id=254
/interface bridge vlan
add bridge=bridge1 tagged=bridge1,ether1 vlan-ids=10
add bridge=bridge1 tagged=bridge1,ether1 vlan-ids=20
add bridge=bridge1 tagged=bridge1,ether1 vlan-ids=254
add bridge=bridge1 frame-types=admit-only-vlan-tagged interface=ether1 internal-path-cost=10 path-cost=10
/interface wifi capsman
set enabled=yes interfaces=vlan20 package-path="" require-peer-certificate=no upgrade-policy=none
/interface wifi provisioning
add action=create-enabled disabled=no master-configuration="Zaposleni 5GHz ax" name-format=Firma-5GHz-ax supported-bands=5ghz-ax
add action=create-enabled disabled=no master-configuration="Zaposleni 2,4GHz ax" name-format=Firma-2,4GHz-ax slave-configurations="Gost ax" supported-bands=2ghz-ax
/interface wifi datapath
add bridge=bridge1 client-isolation=yes disabled=no name=Gosti vlan-id=254
add bridge=bridge1 disabled=no name=Firma vlan-id=10
add address=192.168.88.254/24 interface=vlan10 network=192.168.88.0
add address=192.168.250.254/24 interface=vlan20 network=192.168.250
add disabled=no dst-address=0.0.0.0/0 gateway=192.168.250.1 routing-table=main suppress-hw-offload=no
cAP ax Settup:
add admin-mac=48:A9:8A:C1:A5:CD auto-mac=no name=bridge1
/interface wifi
managed by CAPsMAN
mode: AP, SSID: Zaposleni 5GHz, channel: 5745/ax/Ceee
set [ find default-name=wifi1 ] configuration.manager=capsman .mode=ap
disabled=no
managed by CAPsMAN
mode: AP, SSID:Zaposleni 2,4GHz, channel: 2442/ax
set [ find default-name=wifi2 ] configuration.manager=capsman .mode=ap
disabled=no
/interface vlan
add bridge=bridge1 disabled=no name=datapath1
add bridge=bridge1 frame-types=admit-only-untagged-and-priority-tagged
interface=ether2 pvid=10
add bridge=bridge1 tagged=ether1,bridge1 untagged=ether2 vlan-ids=10
add bridge=bridge1 tagged=ether1,bridge1 vlan-ids=20
/interface wifi cap
set caps-man-addresses=192.168.250.254 discovery-interfaces=vlan20 enabled=yes
slaves-datapath=datapath1
add address=192.168.88.241/24 interface=vlan10 network=192.168.88.0
add address=192.168.250.8/24 interface=vlan20 network=192.168.250.0
If Itry to connect to any SSID, I can connect BUT IP address is not assign.
Why ?
Reason why CAPSMAN is on x86 (noton main router), is that main router is on v6.49.17 and x86 in on v7.13, and cAP ax are new so.....
CAPsMAN
/interface vlan
add action=create-enabled disabled=no master-configuration="Zaposleni 5GHz ax" name-format=%I-wifi supported-bands=5ghz-ax
add action=create-enabled disabled=no master-configuration="Zaposleni 2,4GHz ax" name-format=%I-wifi slave-configurations="Gost ax" supported-bands=2ghz-ax
There is no datapath and wifi configuration, but it looks like you just didn't post that. Who knows?
CAP
add admin-mac=48:A9:8A:C1:A5:CD auto-mac=no name=bridge1 vlan-filtering=yes
/interface wifi
managed by CAPsMAN
disabled=no datapath.bridge=bridge1
managed by CAPsMAN
/interface vlan
add bridge=bridge1 tagged=ether1 untagged=ether2 vlan-ids=10
add bridge=bridge1 tagged=ether1 vlan-ids=254
/interface wifi cap
I add it manualy…Export command don’t show that
Anyone ?
Can’t settup capsman v7 with vlan
You didn’t post any results of suggested changes… so… we are also waiting…
