I am trying to get working VLANs with CAPsMAN, but it seems that it is broken, at least with VLAN filtering. The VLAN looks wrongly assigned to the local AP bridge.
On the AP, which is managed by central CAPsMAN, there is local bridge “bridgeLocal”, which has PVID=3 and enabled VLAN filtering. Under bridge VLANs there are two additional VLANs, 1 and 2. All of these VLANs has assigned ether1 as tagged port and no port as untagged.
When I enable CAP interfaces on the CAPsMAN, there are two scenarios:
- If “no tag” VLAN mode and VLAN=2 is selected in the interface datapath, wlan1 interface gets assigned as untagged to VLAN 1 in bridgeLocal. When client connects, it connects to VLAN 1, not to desired VLAN 2. Also wlan1 port on bridgeLocal has PVID=1.
- If “use tag” VLAN mode and VLAN=2 is selected in the interface datapath, wlan1 interface gets again assigned as untagged to VLAN 1 in bridgeLocal. When client tries to connect, I can see packets flowing from wlan1 with tag 2 to ether1 with tag 2 as well. But packets with opposite directions get filtered in the bridgeLocal. Which is correct behavior. I can fix this by adding wlan1 as tagged port to bridgeLocal VLAN 2, but I think that this should be done by CAPsMAN.
Everything works fine if the datapath is set to “use tag” VLAN mode and bridgeLocal VLAN filtering is disabled. But I would like to enable this in the future.
Model: RouterBOARD wAP G-5HacT2HnD
OS version: 6.42.1
CAPsMAN OS version: 6.42.1
