Capsman VLAN DHCP
iam trying to figure out CAPSMAN with VLAN´s
Till now i use a HAP AC Lite to test my VLAN and Capsman configuration
The Internal Switch is working fine, iam able to get IP address trough vlan ports without problems
But whatever i try WLAN seems not to work.
My Network looks like this
VLAN
10 Management 10.10.0.0/24
20 Internal 10.20.0.0/24
30 Guest 10.30.0.0/24
Accesspoint
add ports=ETH1-Masteruplink,ETH2,ETH3 switch=switch1 vlan-id=20
add ports=ETH1-Masteruplink,switch1-cpu switch=switch1 vlan-id=10
interface ethernet switch port
set 0 vlan-header=add-if-missing vlan-mode=secure
set 1 default-vlan-id=20 vlan-header=always-strip vlan-mode=secure
add address=10.10.0.10/24 interface=vlan10 network=10.10.0.0
add bridge=bridge comment=defconf interface=wlan2
add bridge=bridge interface=ETH1-Masteruplink
Windows DHCP Server is 10.10.0.20
WLAN Internal use Tag VLAN 20
WLAN Guest use Tag VLAN 30
i tried with datapath usetag, local forwarding yes/no, client to client forwarding yes/no
vlan to bridge and bride to datapath
nothing seems to work
i search the internet if anybody got the same problem (they do but no fix seems to help in my matter)
br Martin
