CapsMan, vlan, local forwarding
Hi guys,
we decided to use capsman instead of unfi as the last projects.
I have a general question:
If we use VirtualAp with VLAN tagging in L2 mode: What has do be done on the cap side?
Do we need the vlan config on the CAP manual or will the system provisioned from CapsMan?
Not much on the cap… Use the bridge mode and it works perfectly
Sent from my XT1575 using Tapatalk
