CAPSMAN VLANS and Bridges....
So I am trying to configure CAPSMAN and could use a little advice… I have an existing setup that works (each AP configured manually) which is what I am trying to replicate with CAPSMAN.
My goal is to have a single controller… and 3 RB912s. On each of the RB912s I need to have 2 Wireless Networks (Call them Wireless and GuestWireless). I would like to use the Local Forwarding mode to avoid loading the CAPSMAN server. The traffic coming from Wireless needs to go untagged, while the traffic from GuestWireless needs to be tagged with VLAN ID 1003.
The config for my APs I am trying to convert is below… basically it has three networks going to it… Untagged (should be the main wireless network), Tagged 1 (Management Network), and Tagged 1003 (Guest Network).
Any help is appreciated.
My wireless config for the three RB912s looks like:
add l2mtu=1600 name=bridge-main
add l2mtu=1596 name=bridge-management
add l2mtu=1596 name=bridge-public
set [ find default-name=ether1 ] name=ether01
/interface vlan
add interface=bridge-management l2mtu=1596 name=vlan-management vlan-id=1
add interface=bridge-public l2mtu=1596 name=vlan-public vlan-id=1003
add eap-methods=“” management-protection=allowed name=guest-profile
supplicant-identity=“”
add authentication-types=wpa2-psk eap-methods=“” management-protection=
allowed mode=dynamic-keys name=main-profile supplicant-identity=“”
wpa2-pre-shared-key=123456
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-eC
disabled=no frequency=2412 l2mtu=1600 mode=ap-bridge name=wlan-main
security-profile=main-profile ssid=Wireless tdma-period-size=auto
wireless-protocol=802.11
add disabled=no l2mtu=1600 mac-address=4E:5E:0C:40:EE:19 master-interface=
wlan-main name=wlan-public security-profile=guest-profile ssid=
WirelessGuest wds-cost-range=0 wds-default-cost=0
/ip ipsec proposal
set [ find default=yes ] enc-algorithms=3des
add bridge=bridge-main interface=ether01
add bridge=bridge-main interface=wlan-main
add bridge=bridge-management interface=vlan-management
add bridge=bridge-public interface=vlan-public
add bridge=bridge-public interface=wlan-public
add address=10.1.1.12/24 interface=ether01-vlan-management network=10.1.1.0
add distance=1 gateway=10.1.1.1
Anyone?
Seriously? No one has a clue?
under data path, you can configure what you require. What bridge to use etc.
