CAPsMAN, VLANs & multiple SSIDs headaches
I would leave the capsman part out of it until you have configured the two capac unit and vlans by themselves.
Your current config needs much work but suggestions will just confuse and not help at this point…
The capsman adds a third layer of unnecessary complexity which will get in the way of understanding the other parts to the extent required.
Once the vlans and ac units are configured then I suggest adding in the capsman component.
Best source for reading would be this…
Once you have absorbed and applied the knowledge to your config, I would be more than happy to assist.
