CAPsMAN vs CAPs Connectivity
hi all
ive got a CAPsMAN with about 14 CAPs connected to CAPsMAN with cable
i wanna to install some CAP and connect them to CAPsMAN without cable, is it possible and how can i do it?
tanx
Your proposed configuration is not currently supported within the management scope of CAPsMAN as only AP (Access Point) mode is supported at this time.
please be more specific how you want to connect the CAP without cable to CAPsMAN?
at the moment i connect them with cable, but there is some places in our building that dose not have a good signal, i want to install some CAP in these places and we dont have any cable in these places to connect these CAPs, what shall i do ?
Install double radios. One as client and second as ap.
could you please explain me more about the specification and configuration ?
Cap is connected by network to its manager. It doesn’t matter if it is by wire or if there is some wireless link in between. So just make wifi bridge instead running the wire.
