I had a WiFi wave to simply configured with to APs everything was working fine, then I decided to add slave configuration and hit provision. From that point forward the interfaces are not getting SSIDs assigned even when I reverted to previous configuration. Whenever i hit provision it just shows disabled wifi interfaces. Any idea how to solve it? Here is my current config:
add admin-mac=78:9A:18:EA:CA:11 auto-mac=no comment=defconf name=bridge port-cost-mode=short
/interface wifi
add name=cap-wifi1 radio-mac=F4:1E:57:30:CD:F8
add name=cap-wifi2 radio-mac=F4:1E:57:30:CD:F7
add name=cap-wifi3 radio-mac=F4:1E:57:30:CF:F8
add name=cap-wifi4 radio-mac=F4:1E:57:30:CF:F7
add comment=defconf name=WAN
add comment=defconf name=LAN
/interface wifi datapath
add bridge=bridge disabled=no name=default_datapath
/interface wifi security
add authentication-types=wpa2-psk,wpa3-psk disabled=no ft=yes ft-over-ds=yes name=\
capsman_security
/interface wifi configuration
add country=Poland datapath=default_datapath disabled=no mode=ap name=dream_house_config \
security=capsman_security ssid="Dream house"
add name=dhcp_pool1 ranges=192.168.100.2-192.168.100.254
add address-pool=default-dhcp interface=bridge lease-time=10m name=defconf
/caps-man manager
set enabled=yes
add bridge=bridge comment=defconf interface=ether2 internal-path-cost=10 path-cost=10
add bridge=bridge comment=defconf interface=ether3 internal-path-cost=10 path-cost=10
add bridge=bridge comment=defconf interface=ether4 internal-path-cost=10 path-cost=10
add bridge=bridge comment=defconf interface=ether5 internal-path-cost=10 path-cost=10
add bridge=bridge comment=defconf interface=ether6 internal-path-cost=10 path-cost=10
add bridge=bridge comment=defconf interface=ether7 internal-path-cost=10 path-cost=10
add bridge=bridge comment=defconf interface=ether8 internal-path-cost=10 path-cost=10
add bridge=bridge comment=defconf interface=sfp-sfpplus1 internal-path-cost=10 path-cost=10
set udp-timeout=10s
/interface wifi capsman
set enabled=yes package-path="" require-peer-certificate=no upgrade-policy=none
/interface wifi provisioning
add action=create-dynamic-enabled disabled=no master-configuration=dream_house_config \
radio-mac=00:00:00:00:00:00
add address=192.168.88.1/24 comment=defconf interface=bridge network=192.168.88.0
/ip arp
add address=192.168.88.254 interface=bridge mac-address=B8:27:EB:8C:D0:5A
add address=192.168.88.230 interface=bridge mac-address=A8:A1:59:39:D5:64
add address=192.168.88.228 interface=bridge mac-address=48:0B:B2:50:15:CC
/ip dhcp-client
/ip dhcp-server lease
add address=192.168.88.245 client-id=1:28:c6:8e:34:54:8f mac-address=28:C6:8E:34:54:8F server=\
defconf
add address=192.168.88.0/24 comment=defconf dns-server=192.168.88.1 gateway=192.168.88.1
set allow-remote-requests=yes
/ip dns static
add address=192.168.88.1 comment=mikrotik name=router.lan type=A
add address=192.168.100.1 comment="D-Link modem" name=dlink.modem.lan type=A
add address=192.168.88.231 comment=NAS name=nas.lan type=A
add address=192.168.88.230 comment="Raspberry pi printer server" name=printer-server.lan type=\
A
add address=192.168.88.230 name=server.lan type=A
add action=drop chain=forward comment="Drop NAS connection from internet" dst-address=\
192.168.88.231 in-interface-list=!LAN
add action=drop chain=forward comment="Drop NAS connection to internt" out-interface-list=!LAN \
src-address=192.168.88.231
add action=accept chain=input comment="defconf: accept established,related,untracked" \
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" \
dst-address=127.0.0.1
add action=drop chain=input comment="defconf: drop all not coming from LAN" in-interface-list=\
!LAN
add action=accept chain=forward comment="defconf: accept in ipsec policy" ipsec-policy=\
in,ipsec
add action=accept chain=forward comment="defconf: accept out ipsec policy" ipsec-policy=\
out,ipsec
add action=fasttrack-connection chain=forward comment="defconf: fasttrack" connection-state=\
established,related hw-offload=yes
add action=accept chain=forward comment="defconf: accept established,related, untracked" \
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" \
connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
add action=masquerade chain=srcnat comment="defconf: masquerade" ipsec-policy=out,none \
out-interface-list=WAN
/ip ipsec profile
/ipv6 firewall address-list
/ipv6 firewall filter
add action=accept chain=input comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=33434-33534 \
protocol=udp
add action=accept chain=input comment="defconf: accept DHCPv6-Client prefix delegation." \
dst-port=546 protocol=udp src-address=fe80::/10
add action=accept chain=input comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=input comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=input comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=input comment="defconf: accept all that matches ipsec policy" \
ipsec-policy=in,ipsec
add action=drop chain=input comment="defconf: drop everything else not coming from LAN" \
add action=accept chain=forward comment="defconf: accept established,related,untracked" \
add action=drop chain=forward comment="defconf: drop packets with bad src ipv6" \
src-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: drop packets with bad dst ipv6" \
dst-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: rfc4890 drop hop-limit=1" hop-limit=equal:1 \
protocol=icmpv6
add action=accept chain=forward comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=forward comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=forward comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=forward comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=forward comment="defconf: accept all that matches ipsec policy" \
add action=drop chain=forward comment="defconf: drop everything else not coming from LAN" \
The wifi interfaces status:
[admin@Router] > interface/wifi/print detail
Flags: M - master; D - dynamic; B - bound; X - disabled, I - inactive, R - running
0 M BX name="cap-wifi1" mac-address=F4:1E:57:30:CD:F8 arp-timeout=auto
1 M BX name="cap-wifi2" mac-address=F4:1E:57:30:CD:F7 arp-timeout=auto
2 M BX name="cap-wifi3" mac-address=F4:1E:57:30:CF:F8 arp-timeout=auto
3 M BX name="cap-wifi4" mac-address=F4:1E:57:30:CF:F7 arp-timeout=auto
