Capsman wave2
Can somebody please explain why this thing isnt working? Doing by manual, of course customizing for myself. Two APs: hap ax2 and Audience. Same AP config - different results. Am I insane?
Capsman 5009:
/interface wifiwave2 channel
add band=2ghz-ax disabled=no frequency=2412,2437,2462 name=2ghz-ax secondary-frequency=disabled width=20mhz
add band=2ghz-n disabled=yes frequency=2412,2437,2462 name=2ghz-n secondary-frequency=disabled width=20mhz
add band=5ghz-ac disabled=yes name=5ghz-ac skip-dfs-channels=all width=20/40mhz
add band=5ghz-ax disabled=no name=5ghz-ax skip-dfs-channels=all width=20/40mhz
/interface wifiwave2 datapath
add bridge=bridge1 disabled=no name=vlan240 vlan-id=240
add bridge=bridge1 disabled=no name=vlan247 vlan-id=247
/interface wifiwave2 security
add authentication-types=wpa2-psk,wpa3-psk disable-pmkid=yes disabled=no group-encryption=ccmp group-key-update=1h \
    management-protection=allowed name=UTMT wps=disable
/interface wifiwave2 configuration
add chains=0,1,2,3 channel=5ghz-ax country=Russia datapath=vlan240 disabled=no manager=capsman mode=ap name=UTMT-5 rrm=yes \
    security=UTMT ssid=UTMT tx-chains=0,1,2,3 tx-power=12
add chains=0,1,2,3 channel=2ghz-n country=Russia datapath=vlan240 disabled=no manager=capsman mode=ap name=UTMT-2 rrm=yes \
/interface wifiwave2 capsman
set ca-certificate=none enabled=yes interfaces=all package-path="" require-peer-certificate=no upgrade-policy=none
/interface wifiwave2 provisioning
add action=create-dynamic-enabled disabled=no master-configuration=UTMT-2 name-format=2G-%I supported-bands=2ghz-ax
add action=create-dynamic-enabled disabled=no master-configuration=UTMT-5 name-format=5G-%I supported-bands=5ghz-ax,5ghz-ac
hap ax2:
managed by CAPsMAN
set [ find default-name=wifi1 ] configuration.manager=capsman .mode=ap datapath=cap disabled=no
managed by CAPsMAN
set [ find default-name=wifi2 ] configuration.manager=capsman .mode=ap datapath=cap disabled=no
set caps-man-addresses=192.168.241.254 certificate=none discovery-interfaces=vlan241-mgmt enabled=yes
add bridge=bridge1 disabled=no name=cap
Audience:
managed by CAPsMAN
managed by CAPsMAN
managed by CAPsMAN
set [ find default-name=wifi3 ] configuration.manager=capsman .mode=ap datapath=cap disabled=no
Capsman address was added for “just maybe” case, result is the same with L2 communication.
vlan filtering is proper, was used on capsman v1 before, bridge interface added to vlan “just in case” too
And the result is:
Somehow capsman doesnt push vlan ID to caps, have to do it locally like this
# managed by CAPsMAN
# mode: AP, SSID: UTMT, channel: 5540/ax/Ce
set [ find default-name=wifi1 ] configuration.manager=capsman .mode=ap datapath=vlan240 disabled=no
# mode: AP, SSID: UTMT, channel: 2412/ax
set [ find default-name=wifi2 ] configuration.manager=capsman .mode=ap datapath=vlan240 disabled=no
And for slaves separately
set certificate=none discovery-interfaces=vlan241-mgmt enabled=yes slaves-datapath=vlan240
But what if I need multiple slaves in different vlans?
Also it doesn’t say, but I presume channel higher standard config includes previous standards?
And we’re discriminating in provision?
add action=create-dynamic-enabled disabled=no master-configuration=UTMT-2ax name-format=2G-%I supported-bands=2ghz-ax,2ghz-n
add action=create-dynamic-enabled disabled=no master-configuration=UTMT-5ax name-format=5G-%I supported-bands=5ghz-ax,5ghz-ac
Cause right now it work with older devices which doesnt support ax.
Ok current working capsman config is:
    management-protection=allowed name=Guest wps=disable
add channel=5ghz-ax country=Russia datapath=vlan240 disabled=no mode=ap name=UTMT-5g security=UTMT ssid=UTMT tx-power=12
add channel=2ghz-ax country=Russia datapath=vlan240 disabled=no mode=ap name=UTMT-2g security=UTMT ssid=UTMT tx-power=12
add channel=5ghz-ax country=Russia datapath=vlan247 disabled=no mode=ap name=Guest-5g security=Guest ssid=Guest
add channel=2ghz-ax country=Russia datapath=vlan247 disabled=no mode=ap name=Guest-2g security=Guest ssid=Guest
set ca-certificate=none enabled=yes interfaces=vlan241-mgmt package-path="" require-peer-certificate=no upgrade-policy=none
add action=create-dynamic-enabled disabled=no master-configuration=UTMT-2g name-format=2G-%I slave-configurations=Guest-2g \
add action=create-dynamic-enabled disabled=no master-configuration=UTMT-5g name-format=5G-%I slave-configurations=Guest-5g \
For hap ax2 as CAP:
managed by CAPsMAN
managed by CAPsMAN
mode: AP, SSID: UTMT, channel: 2462/ax
set certificate=none discovery-interfaces=vlan241-mgmt enabled=yes slaves-datapath=vlan247
add bridge=bridge1 client-isolation=yes disabled=no name=vlan247 vlan-id=247
Still cannot make Audience work with that config. Hoping for mikrotik’s reps advice.
Found the topic when got different error
http://forum.mikrotik.com/t/capsmanv2-configuration-for-secondary-ssids-on-different-vlans/166154/1
Thanks mikrotik, as always user is unaware about ongoing bugs and should read tonns of forums and changelog and use beta.
