I’m configuring capsman, I would like to ensure that when the user moves between the various cAPs the connection does not drop but roaming occurs. Does the configuration seem correct to you?
/interface wifi channel
add band=2ghz-ax disabled=no frequency=2412 name=channel1 skip-dfs-channels=disabled width=20/40mhz
add band=2ghz-ax disabled=no frequency=2437 name=channel6 skip-dfs-channels=disabled width=20/40mhz
add band=2ghz-ax disabled=no frequency=2462 name=channel11 skip-dfs-channels=disabled width=20/40mhz
add band=5ghz-ax disabled=no frequency=5260 name=channel52 width=20/40/80mhz
add band=5ghz-ax disabled=no frequency=5180 name=channel36 width=20/40/80mhz
add band=5ghz-ax disabled=no frequency=5500 name=channel100 width=20/40/80mhz
add band=5ghz-ax disabled=no frequency=5600 name=channel116 width=20/40/80mhz
/interface wifi datapath
add bridge=bridge-main disabled=no interface-list=LAN name=datapath-vlan1 vlan-id=1
add bridge=bridge-main client-isolation=yes disabled=no interface-list=GUEST name=datapath-vlan333 vlan-id=333
/interface wifi security
add authentication-types=wpa2-psk,wpa3-psk disabled=no encryption="" ft=yes ft-over-ds=yes name=security-private
add disabled=no ft=yes ft-over-ds=yes name=security-guest
/interface wifi configuration
add antenna-gain=0 channel=channel1 datapath=datapath-vlan1 disabled=no mode=ap name=cfg1-2.4Ghz-private security=security-private ssid="Al Convento Private"
add antenna-gain=0 channel=channel6 datapath=datapath-vlan1 disabled=no mode=ap name=cfg6-2.4Ghz-private security=security-private ssid="Al Convento Private"
add antenna-gain=0 channel=channel52 datapath=datapath-vlan1 disabled=no name=cfg52-5GHz-private security=security-private ssid="Al Convento Private"
add antenna-gain=0 channel=channel36 datapath=datapath-vlan1 disabled=no name=cfg36-5GHz-private security=security-private ssid="Al Convento Private"
add antenna-gain=0 channel=channel100 datapath=datapath-vlan1 disabled=no name=cfg100-5GHz-private security=security-private ssid="Al Convento Private"
add antenna-gain=0 channel=channel1 datapath=datapath-vlan333 disabled=no mode=ap name=cfg1-2.4Ghz-GUEST security=security-guest ssid="B&B Al Convento Ospiti"
add antenna-gain=0 channel=channel6 datapath=datapath-vlan333 disabled=no mode=ap name=cfg6-2.4Ghz-GUEST security=security-guest ssid="B&B Al Convento Ospiti"
add antenna-gain=0 channel=channel11 datapath=datapath-vlan333 disabled=no mode=ap name=cfg11-2.4Ghz-GUEST security=security-guest ssid="B&B Al Convento Ospiti"
add antenna-gain=0 channel=channel36 datapath=datapath-vlan333 disabled=no name=cfg36-5GHz-GUEST security=security-guest ssid="B&B Al Convento Ospiti"
add antenna-gain=0 channel=channel11 datapath=datapath-vlan1 disabled=no mode=ap name=cfg11-2.4Ghz-private security=security-private ssid="Al Convento Private"
add antenna-gain=0 channel=channel52 datapath=datapath-vlan333 disabled=no name=cfg52-5GHz-GUEST security=security-guest ssid="B&B Al Convento Ospiti"
add antenna-gain=0 channel=channel100 datapath=datapath-vlan333 disabled=no mode=ap name=cfg100-5GHz-GUEST security=security-guest ssid="B&B Al Convento Ospiti"
add antenna-gain=0 channel=channel116 datapath=datapath-vlan333 disabled=no name=cfg116-5GHz-GUEST security=security-guest ssid="B&B Al Convento Ospiti"
add antenna-gain=0 channel=channel116 datapath=datapath-vlan1 disabled=no name=cfg116-5GHz-private security=security-private ssid="Al Convento Private"
/interface wifi access-list
add action=reject allow-signal-out-of-range=4s disabled=no signal-range=-120..-77
/interface wifi cap
set discovery-interfaces=vlan1-LAN enabled=yes
/interface wifi capsman
set ca-certificate=auto enabled=yes interfaces=vlan1-LAN package-path="" require-peer-certificate=no upgrade-policy=none
/interface wifi provisioning
add action=create-dynamic-enabled comment="AP1 2.4ghz" disabled=no master-configuration=cfg1-2.4Ghz-private name-format=%I-2.4GHz radio-mac=D4:01:C3:F1:E6:B1 slave-configurations=cfg1-2.4Ghz-GUEST supported-bands=\
2ghz-ax
add action=create-dynamic-enabled comment="AP3 2.4ghz" disabled=no master-configuration=cfg6-2.4Ghz-private name-format=%I-2.4GHz radio-mac=D4:01:C3:F1:D3:81 slave-configurations=cfg6-2.4Ghz-GUEST supported-bands=\
2ghz-ax
add action=create-dynamic-enabled comment="AP1 - 5GHz" disabled=no master-configuration=cfg36-5GHz-private name-format=%I-5GHz radio-mac=D4:01:C3:F1:E6:B0 slave-configurations=cfg36-5GHz-GUEST supported-bands=5ghz-ax
add action=create-dynamic-enabled comment="hAP ax2 - 2.4Ghz" disabled=no master-configuration=cfg6-2.4Ghz-private name-format=%I radio-mac=D4:01:C3:E1:25:B1 slave-configurations=cfg6-2.4Ghz-GUEST supported-bands=\
2ghz-ax
add action=create-dynamic-enabled comment="hAP ax2 - %5GHz" disabled=no master-configuration=cfg52-5GHz-private name-format=%I radio-mac=D4:01:C3:E1:25:B0 slave-configurations=cfg52-5GHz-GUEST
add action=create-dynamic-enabled disabled=no master-configuration=cfg100-5GHz-private name-format=FABIO-5GHZ radio-mac=78:9A:18:27:D2:A8 slave-configurations=cfg100-5GHz-GUEST supported-bands=5ghz-ax
add action=create-dynamic-enabled disabled=no master-configuration=cfg11-2.4Ghz-private name-format=FABIO-2GHZ radio-mac=78:9A:18:27:D2:A9 slave-configurations=cfg11-2.4Ghz-GUEST supported-bands=2ghz-ax
add action=create-dynamic-enabled comment=AP2-5GHz disabled=no master-configuration=cfg100-5GHz-private name-format=%I-5GHz radio-mac=D4:01:C3:F1:D2:ED slave-configurations=cfg100-5GHz-GUEST supported-bands=5ghz-ax
add action=create-dynamic-enabled comment=AP3-5GHz disabled=no master-configuration=cfg52-5GHz-private name-format=%I-5GHz radio-mac=D4:01:C3:F1:D3:80 slave-configurations=cfg52-5GHz-GUEST supported-bands=5ghz-ax
add action=create-dynamic-enabled comment=AP2-2.4GHz disabled=no master-configuration=cfg11-2.4Ghz-private name-format=%I-2.4GHz radio-mac=D4:01:C3:F1:D2:EE slave-configurations=cfg11-2.4Ghz-GUEST supported-bands=\
2ghz-ax
