Capsman with 2 SSID
I am trying to setup Capsman to support havin separate SSID for 2,4 GHz and 5 GHz.. Before I used the same SSID for both, but I want to be able to choose 5 GHz for increased speed… BUT, as I started to change - basically whatever I do fails… And Capsman is totally unstable.. As is, I will have to remove Capsman entirely as it does not work.. Does anyone have a simple enoug step-by-step instruction to set it up working..
Export your capsman config
Capsman Works Perfect, of the config is right
OK, here comes…
/caps-man interface
add disabled=no mac-address=E4:8D:8C:50:BA:BD master-interface=none name=cap1 radio-mac=E4:8D:8C:50:BA:BD
add disabled=no mac-address=E4:8D:8C:44:0C:8F master-interface=none name=cap2 radio-mac=E4:8D:8C:44:0C:8F
add disabled=no mac-address=00:0C:42:FC:9F:5D master-interface=none name=cap3 radio-mac=00:0C:42:FC:9F:5D
/caps-man datapath
add bridge=PautaNet name=Pauta
/caps-man security
add authentication-types=wpa-psk,wpa2-psk encryption=aes-ccm group-encryption=aes-ccm name=security1 passphrase=xxx
/caps-man configuration
add channel.band=5ghz-a/n/ac country=sweden datapath=Pauta datapath.bridge=PautaNet mode=ap name=Pauta50 security=security1 ssid=Pauta50
add channel.band=2ghz-b/g/n country=sweden datapath=Pauta datapath.bridge=PautaNet mode=ap name=Pauta24 security=security1 ssid=Pauta24
/caps-man access-list
add action=accept disabled=no interface=all signal-range=-80..120 ssid-regexp=“” time=0s-1d,sun,mon,tue,wed,thu,fri,sat
add action=reject disabled=no interface=all signal-range=-120..-81 ssid-regexp=“” time=0s-1d,sun,mon,tue,wed,thu,fri,sat
/caps-man manager
set enabled=yes
/caps-man provisioning
add action=create-dynamic-enabled master-configuration=Pauta50 name-format=prefix-identity name-prefix=Pauta50
add action=create-dynamic-enabled master-configuration=Pauta24 name-format=prefix-identity name-prefix=Pauta24
BTW - I used 6.39.1. Not working. For the sake of it I tried to upgrade to 6.40rc5 - but still not working.
Have now tried to setup Capsman on another RB from scratch - but it does not work. I can get eithe 2.4 or 5 Ghz to work, but never simultaneously with different SSID´s... Pasting the config below, possibly a bit messed-up as I have tried to fiddle around a bit...
may/14/2017 12:32:00 by RouterOS 6.39.1
software id = 9YSZ-622Y
/caps-man channel
add band=2ghz-g/n control-channel-width=20mhz name=channel24
add band=5ghz-a/n/ac control-channel-width=20mhz name=channel50
/caps-man interface
add disabled=no l2mtu=1600 mac-address=E4:8D:8C:4B:25:FC master-interface=
none name=cap1 radio-mac=E4:8D:8C:4B:25:FC
/caps-man datapath
add bridge=PautaNet name=PautaNet
add bridge=PautaNet2 name=PautaNet2
/caps-man security
add channel=channel24 country=sweden datapath=PautaNet name=Pauta24 security=
add channel=channel50 country=sweden datapath=PautaNet2 name=Pauta50
/caps-man manager
set enabled=yes
add action=create-dynamic-enabled hw-supported-modes=ac master-configuration=
add action=create-dynamic-enabled hw-supported-modes=gn master-configuration=
Pauta24 name-format=prefix-identity name-prefix=Pauta24 radio-mac=
01:00:00:00:00:00
Take a Look alt this:
https://mum.mikrotik.com/presentations/EU17/presentation_4059_1492080639.pdf
OK. Still can not figure out why not working. I had it working with one single SSID for 4 AP´s. Now I try only with one WAP AC, using 2 SSID´s to separate the 5 GHz but it never works. I follow the basic steps:
  1. Activate Capsman
  2. Create a bridge
  3. Define configuration. Have tested several different variants but basically one configuration per SSID with minimum “band” defined. Have also tried to define in Channels separately.
  4. Define Provisioning. Have tried both with one Master and one Slave as well as 2 separate Provisioning rules.
  5. Set CAP in AP to point to CapsMan.
For the moment the 2,4 network states “no supported band” and can not be controlled nor is the SSID visible…
So, something fundamental must be missing taking into account I have fiddled around with most available settings…
Made a stupid mistake. On CAP is had not set “bridge”… Working now…
