CapsMan with DualBand
Hello
I’m trying to set up 2 Mikrotik Cap ac, with the Capsman function, but I have a problem.When I enable the Capsman functionallity in to the wireless interface only one band works at a time. So it works 2,4Ghz or 5Ghz I don’t know how to let works at the same time.Anyone can help me ? Thank you
Please share your current configuration: /caps-man export hide-sensitive
If caps-man is running on your router…
Telnet to the capAC.
/system reset-configuration skip-backup=yes caps-mode=yes
have you enable both interfaces to be managed by capsman?
You need to create slave config for the other band.
