CAPsMAN with multi passphrase group configuration - help needed
Hi all.
I am trying to get the CAPsMAN with multi passphrase group configuration to work and could need some help.
The following VLANs should be available via wifi:
- 1000
- 1010
- 1060
The L2 connectivity is proven working between CAPsMAN device and AP.
The AP has an IP address in the prefix on VLAN 999 (no wifi for this VLAN) over which it should be managed by CAPsMAN (also used for SSH and API calls etc.).
I want to make use of the multi passphrase groups. VLAN assignment seems to work according to the registration table on the CAPsMAN device, but there is no traffic I can see.
I had a working CAPsMAN setup with the old wireless package (if I am not mistaken) but as this is deprecated I wanted to migrate over to the wifi package.
Below is the current configuration (not working) with all the unused interfaces etc. removed. The VLANs are tagged on all network devices along the paht.
CAPsMAN
[user@capsman] > /system/package/print
Flags: X - DISABLED
Columns: NAME, VERSION, BUILD-TIME, SIZE
#   NAME      VERSION  BUILD-TIME           SIZE
0 X wireless  7.21.1   2026-01-19 15:09:07  860.1KiB
1   routeros  7.21.1   2026-01-19 15:09:07  12.8MiB
[user@capsman] > /interface/export show-sensitive
# 2026-02-01 16:43:43 by RouterOS 7.21.1
# model = CCR2116-12G-4S+
set [ find default-name=sfp-sfpplus1 ] comment=\
"Core;spinesw01.home sfp-sfpplus1;C0000118;" l2mtu=1598
set [ find default-name=sfp-sfpplus2 ] comment=\
"Core;spinesw02.home sfp-sfpplus1;C0000119;" l2mtu=1598
set [ find default-name=sfp-sfpplus3 ] comment=";;;" disabled=yes l2mtu=1598
set [ find default-name=sfp-sfpplus4 ] comment=";;;" disabled=yes l2mtu=1598
/interface bonding
add comment="LACP to spinesw0[12].home" mode=802.3ad name=bond1 slaves=sfp-sfpplus1,sfp-sfpplus2 \
transmit-hash-policy=layer-2-and-3
/interface vlan
add interface=bond1 name=vl-999-mgmt vlan-id=999
add interface=bond1 name=vl-1000-int vlan-id=1000
add interface=bond1 name=vl-1010-media vlan-id=1010
add interface=bond1 name=vl-1060-work vlan-id=1060
/interface vrrp
add interface=vl-1000-int name=vrrp-int priority=254 remote-address=10.10.0.252 \
sync-connection-tracking=yes
add interface=vl-1010-media name=vrrp-media priority=254 remote-address=10.10.1.252 \
add interface=vl-999-mgmt name=vrrp-mgmt priority=254 remote-address=10.10.99.252 \
add interface=vl-1060-work name=vrrp-work priority=254 remote-address=10.10.6.252 \
/interface wifi channel
add disabled=no name=private-2 skip-dfs-channels=10min-cac
add band=5ghz-ax disabled=yes name=private-5 skip-dfs-channels=10min-cac width=20/40/80mhz
/interface wifi datapath
add disabled=no name=int traffic-processing=on-cap vlan-id=1000
add disabled=no name=media traffic-processing=on-cap vlan-id=1010
add disabled=no name=work traffic-processing=on-cap vlan-id=1060
/interface wifi security
add authentication-types=wpa2-psk disabled=no encryption=ccmp ft=yes ft-over-ds=yes \
multi-passphrase-group=private name=wifi-private wps=disable
/interface wifi configuration
add channel=private-2 country=Germany datapath=media disabled=no installation=indoor mode=ap name=media-2 \
security=wifi-private ssid=myssid
add channel=private-2 country=Germany datapath=work disabled=no installation=indoor mode=ap name=work-2 \
add channel=private-2 country=Germany datapath=int disabled=no installation=indoor mode=ap name=int-2 \
add channel=private-5 country=Germany datapath=int disabled=no installation=indoor mode=ap name=int-5 \
add channel=private-5 country=Germany datapath=media disabled=no installation=indoor mode=ap name=\
    media-5 security=wifi-private ssid=myssid
add channel=private-5 country=Germany datapath=work disabled=no installation=indoor mode=ap name=work-5 \
/interface ethernet switch
set 0 l3-hw-offloading=yes
/interface wifi capsman
set ca-certificate=WiFi-CAPsMAN-CA-something enabled=yes interfaces=vl-999-mgmt
/interface wifi provisioning
add action=create-dynamic-enabled disabled=no master-configuration=int-2 name-format=%I-2.4 \
slave-configurations=media-2,work-2 slave-name-format=%I-2.4-virtual supported-bands=2ghz-ax
add action=create-dynamic-enabled disabled=no master-configuration=int-5 name-format=%I-5 \
slave-configurations=media-5,work-5 slave-name-format=%I-5-virtual supported-bands=5ghz-ax
/interface wifi security multi-passphrase
add comment=int disabled=no group=private passphrase=pw1 vlan-id=1000
add comment=media disabled=no group=private passphrase=pw2 vlan-id=1010
add comment=work disabled=no group=private passphrase=pw3 vlan-id=1060
add address=10.10.99.253/24 interface=vl-999-mgmt network=10.10.99.0
add address=10.10.99.254/24 interface=vrrp-mgmt network=10.10.99.0
add address=10.10.0.253/24 interface=vl-1000-int network=10.10.0.0
add address=10.10.0.254/24 interface=vrrp-int network=10.10.0.0
add address=10.10.1.253/24 interface=vl-1010-media network=10.10.1.0
add address=10.10.1.254/24 interface=vrrp-media network=10.10.1.0
add address=10.10.6.253/24 interface=vl-1060-work network=10.10.6.0
add address=10.10.6.254/24 interface=vrrp-work network=10.10.6.0
Accesspoint
[user@cap] > /system/package/print
0 routeros   7.21.1   2026-01-19 15:09:07  12.8MiB
1 wifi-qcom  7.21.1   2026-01-19 15:09:07  12.1MiB
[user@cap] > /interface/export show-sensitive
# 2026-02-01 16:44:01 by RouterOS 7.21.1
# model = cAPGi-5HaxD2HaxD
add mtu=1500 name=general-bridge vlan-filtering=yes
/interface wifi
# managed by CAPsMAN capsmanmacaddress%vl-999-mgmt, traffic processing on CAP
# mode: AP, SSID: myssid, channel: 5680/ax/eCee/D
set [ find default-name=wifi1 ] channel.band=5ghz-ax .skip-dfs-channels=10min-cac .width=20/40/80mhz \
configuration.manager=capsman .mode=ap .ssid=MikroTik-something disabled=no \
security.authentication-types=wpa2-psk,wpa3-psk .ft=yes .ft-over-ds=yes .passphrase=defaultpw
# mode: AP, SSID: myssid, channel: 2412/ax/Ce
set [ find default-name=wifi2 ] channel.band=2ghz-ax .skip-dfs-channels=10min-cac .width=20/40mhz \
add disabled=no master-interface=wifi1 name=wifi5
add disabled=no master-interface=wifi1 name=wifi6
add disabled=no master-interface=wifi2 name=wifi7
add disabled=no master-interface=wifi2 name=wifi8
set [ find default-name=ether1 ] comment="Access;WPS-Corridor-01 1;;"
set [ find default-name=ether2 ] comment=";;;" disabled=yes
/interface vlan
add interface=general-bridge name=vl-999-mgmt vlan-id=999
add bridge=general-bridge frame-types=admit-only-vlan-tagged interface=ether1
/interface bridge vlan
add bridge=general-bridge tagged=ether1,general-bridge vlan-ids=999
add bridge=general-bridge tagged=ether1 vlan-ids=1000
add bridge=general-bridge tagged=ether1 vlan-ids=1010
add bridge=general-bridge tagged=ether1 vlan-ids=1060
/interface wifi cap
set caps-man-addresses=10.10.99.253 caps-man-names=fw01.home certificate=request \
discovery-interfaces=vl-999-mgmt enabled=yes slaves-static=yes
add address=10.10.99.243/24 interface=vl-999-mgmt network=10.10.99.0
What hardware is used as CAP?
The CAPs are cAP ax (cAPGi-5HaxD2HaxD).
Thanks for the info as there is a big difference with wifi-qcom and wifi-qcom-ac devices.
CAP
You can remove all "slave" wifi interfaces.
No need to set anything on the wif interfaces of the CAP, other then manager (as you did as well)
CAPsMAN
Single datapath is sufficient, remove vlan-id and add bridge
Single configuration (or split per radio) with single datapath is sufficient
Hope it helps!
I cannot add the bridge as my router (CAPsMAN) doesn't have one.
The changed configuration now looks as follows but after successful authentication and registration via wifi I still see no traffic (e.g. DHCP not workng).
add band=5ghz-ax disabled=no name=private-5 skip-dfs-channels=10min-cac width=20/40/80mhz
add name=wifi traffic-processing=on-cap
add authentication-types=wpa2-psk disabled=no encryption=ccmp ft=yes ft-over-ds=yes multi-passphrase-group=private name=wifi-private wps=disable
add channel=private-2 country=Germany datapath=wifi installation=indoor mode=ap name=wifi-2.4 security=wifi-private ssid=myssid
add channel=private-5 country=Germany datapath=wifi installation=indoor mode=ap name=wifi-5 security=wifi-private ssid=myssid
add action=create-dynamic-enabled master-configuration=wifi-2.4 name-format=%I-2.4 supported-bands=2ghz-ax
add action=create-dynamic-enabled master-configuration=wifi-5 name-format=%I-5 supported-bands=5ghz-ax
add comment=int disabled=no group=private vlan-id=1000
add comment=media disabled=no group=private vlan-id=1010
add comment=work disabled=no group=private vlan-id=1060
/interface wifi
# mode: AP, SSID: myssid, channel: 5700/ax/eeCe/D
set [ find default-name=wifi1 ] configuration.manager=capsman disabled=no
set [ find default-name=wifi2 ] configuration.manager=capsman disabled=no
/interface wifi cap
I would expect some additions to the CAP:
Instead of this:
/interface wifi cap
Change it to:
add brdige=general-bridge disabled=no name=capdp
/interface wifi cap
slaves-datapath=capdp discovery-interfaces=vl-999-mgmt enabled=yes
I adjusted that now, also, but without success until now.
I was inspecting the wifi interfaces and the bridge. I only saw DHCP requests on the wifi interface but not in the bridge so I guess the CAP doesn't forward this traffic. It has only input firewall rules, nothing for forward so it also shouldn't block anything.
Would be helpful if you share the adjusted configs as well.
The problem is wifi related? VLAN is working?
Yes, the VLAN itself is definitely working.
For another test I just executed
/interface/bridge/port/add bridge=general-bridge interface=ether2 pvid=1000
/interface/ethernet/enable ether2
and the client does get an IP address via DHCP via this VLAN. This is the same VLAN (1000) I see in the registration table on the CAPsMAN device.
The current config looks as follows.
CAPsMAN
CAP
/interface wifi
add bridge=general-bridge name=capdp
/interface wifi cap
    discovery-interfaces=vl-999-mgmt enabled=yes slaves-datapath=capdp
As you don't have a bridge on the CAPsMAN, I think you don't have to have a datapath. Can you adjust the /interface wifi configuration so it's datapath isn't set?
add channel=private-2 country=Germany installation=indoor mode=ap name=wifi-2.4 security=wifi-private ssid=myssid
add channel=private-5 country=Germany installation=indoor mode=ap name=wifi-5 security=wifi-private ssid=myssid
So I followed your step but that didn’t help. Then I took a look at the CAP and saw that no datapath was configured on the interface so I did that and now it is working. I guess the “slaves-datapath” property for “/interface/wifi/cap” actually only is for slave interfaces which I do not have as of now. I can confirm this is working for all the mentioned VLANs.
Thank you very much for your help and assistance.
I bet this would have been quicker if it was all defaulted.
