CAPsMAN with WifiWave2
At the risk of mentioning the obvious … wifiwave2 package is installed on CCR for capsman ?
If not, there is your problem.
You can not mix legacy wifi and wifiwave2 devices in capsman.
No, wifiwave2 package is not installed on CCR.
Can one CCR control wifiwave2 and ‘legacy’ wifi devices?
(why is it called legacy? the cAPs are still available in the shops)
I call it legacy because “old” sounds too… old :laughing:
For me it is legacy since there is zero development on it already for some time, even on ROS6 as a whole ( except for some security fixes).
I am not alone labeling it as such.
And yes, you can still buy them.
I have also purchased some mAP and mAP Lite 2 weeks ago for a specific purpose.
One controller can not mix two capsman environments.
But you can run 2 controllers on the same network.
Most wifiwave2 APs are powerful enough to also be used as controller if you don’t have a dedicated device available (yet).
old :laughing:
Okay, so first decision is
  • replace all cAP with cAP ax for staying with one management device
    or
  • create a second controller on a cAP ax with a complete wifi ‘parallel world’
    No management of both worlds on a single device?
    (even not on the 2004? it should have enough resources)
Nope, can’t be done.
All router functions ( dhcp, firewall, dns, vlan termination, …) can be done on 1 device. But not wifi management.
Okay, thanks for the clear answer.
Would you go with 2 wifi controllers or replace all with wifiwave2 (or even stay with cAP?)
Depends on the number of devices to be replaced.
Also depends on the requirements for that wifi environment. What is it being used for ?
There are + and - for both options.
E.g.
  • no need to fork out the investment right away if you gradually replace but eventually it will be needed.
  • if however you can benefit from roaming from ap to ap, definitely go for replacement. Huge difference between “old” and new !!
I can think of some other arguments pro and con but you get the idea, I hope.
Roaming between APs is actually not really good.
If wifiwave2 makes a big plus here, it would be a very good reason for replacing all cAPs with cAPs ax.
There you go then.
Time to write the investment request :laughing:
:smiley:
I found an old CRS326 - maybe this works well as an intermediate controller for the old ones.
Depends on number of caps and type.
Cap ac, certainly yes.
Cap / Cap lite, might still be possible.
Crs326, I doubt it.
Ps please don’t change post after reply has been given.
I’d say that legacy capsman controller on a crs326 depends on use case.
Do you use capsman forwarding? If yes, then the crs326 would not be a good choice. Otherwise the crs326 would be primarily for provisioning and should work fine.
I had multiple capsman controllers and one was a crs326 and it worked great when my primary was down.
@holvoetn yes, you’re right - sorry for confusion.
@biomesh capsman forwarding is active at the moment. If it’s getting to slow, I’ll try local forwarding.
