Hello. Simple question. I have a hEX RB750Gr2 with 6.37.3 installed, L4 license. No built in AP. I was under the impression that I could use the CAPsMAN for 4 wAPs. I don’t have CAPsMAN in my main menu. What am I missing?
Hi. The wireless package needs to be enabled. Try the below:
/system package enable wireless
Then after a reboot you should see the CAPsMAN menu
