Hello everyone!
The setup:
one RB750Gr2 under 6.39.1
two RBwAPG-5HacT2HnD under 6.39.1
I use my primary RB750Gr2 to manage my two AP with CAPsMAN…
I got 3 ssid configured, one “admin” 5Ghz, one “admin” 2.4 and one “guest” 2.4.
I see the three ssid, I’m able to connect to three of them and I got private 192.168.1.x address on both “admin” but no internet, I can only ping 192.168.1.1 (DHCP pool 192.168.1.100-254)
BUTT I have separate dhcp server for guest under 10.0.0.1 who serve 10.0.0.100-254 and it ping 8.8.8.8 and internet work well on guest only…
The configs are the “same”, only dhcp binding and bridge is different..
Any idea?!
Dave
Without seeing the rest of your conifg, I’d start with double-checking your NAT and Firewall.
matiaszon:
It does say nothing.
/export hide-sensitive
[admin@MikroTik] > /export hide-sensitive
# may/05/2017 13:14:16 by RouterOS 6.39.1
# software id = PGU7-MYBT
add mtu=1500 name=Guest
add mtu=1500 name=OfficeNet
set [ find default-name=ether1 ] name=ether1-gateway
set [ find default-name=ether2 ] name=ether2-master-local
set [ find default-name=ether3 ] master-port=ether2-master-local name=ether3-slave-local
set [ find default-name=ether4 ] master-port=ether2-master-local name=ether4-slave-local
set [ find default-name=ether5 ] master-port=ether2-master-local name=ether5-slave-local
/ip neighbor discovery
set ether1-gateway discover=no
/caps-man configuration
add datapath.bridge=OfficeNet name=OfficeNet security.authentication-types=wpa-psk,wpa-eap security.encryption=aes-ccm,tkip security.group-encryption=\
aes-ccm ssid=Office
add datapath.bridge=Guest name=Guest security.authentication-types=wpa-psk,wpa-eap security.encryption=aes-ccm,tkip security.group-encryption=aes-ccm \
ssid=Guesttata
/caps-man interface
add channel.band=2ghz-b/g/n configuration=OfficeNet configuration.hide-ssid=no configuration.mode=ap configuration.ssid=Testzouiz datapath.bridge=\
OfficeNet disabled=no l2mtu=1600 mac-address=6C:3B:6B:B7:0B:48 master-interface=none name=cap1 radio-mac=6C:3B:6B:B7:0B:48 \
security.authentication-types=wpa-psk security.encryption=aes-ccm,tkip security.group-encryption=aes-ccm
add channel.band=5ghz-a/n/ac configuration=OfficeNet configuration.hide-ssid=no configuration.mode=ap configuration.ssid=Test5 datapath.bridge=OfficeNet \
disabled=no l2mtu=1600 mac-address=6C:3B:6B:B7:0B:47 master-interface=none name=cap2 radio-mac=6C:3B:6B:B7:0B:47 security.authentication-types=\
add channel.band=2ghz-b/g/n configuration=Guest configuration.hide-ssid=no configuration.mode=ap configuration.ssid="FBI Guest" datapath.bridge=Guest \
disabled=no l2mtu=1600 mac-address=6E:3B:6B:B7:0B:48 master-interface=cap1 name=cap3 radio-mac=00:00:00:00:00:00 security.authentication-types=\
/ip firewall layer7-protocol
add name=Block regexp="^.+(youporn.com|pornhub.com).*\$"
add name=Youtube regexp="^.+(https://www.youtube.com).*\$"
/ip hotspot profile
/ip ipsec proposal
set [ find default=yes ] enc-algorithms=aes-256-cbc,aes-128-cbc,3des pfs-group=none
add name=dhcp ranges=192.168.1.100-192.168.1.254
add name=vpn-pool ranges=192.168.10.10-192.168.10.20
add name=OfficeNet ranges=192.168.100.2-192.168.100.254
add name=GuestPool ranges=10.0.0.2-10.0.0.254
add address-pool=dhcp disabled=no interface=ether2-master-local name=default
add address-pool=dhcp disabled=no interface=OfficeNet name=CAP
add address-pool=GuestPool disabled=no interface=Guest name=dhcp2
/ppp profile
add dns-server=8.8.8.8 local-address=192.168.10.1 name=pptp_profile remote-address=vpn-pool use-encryption=yes
add change-tcp-mss=yes local-address=vpn-pool name=l2tp-profile remote-address=vpn-pool use-encryption=required
/queue tree
add disabled=yes name=Stable-Ping packet-mark=Ping-Packet parent=global
/system logging action
set 1 disk-file-name=log
/user group
add name=sniffer policy=ssh,read,!local,!telnet,!ftp,!reboot,!write,!policy,!test,!winbox,!password,!web,!sniff,!sensitive,!api,!romon,!dude,!tikapp
/caps-man manager
set enabled=yes
/caps-man provisioning
add action=create-dynamic-enabled disabled=yes master-configuration=OfficeNet name-prefix=AP
/interface l2tp-server server
set authentication=mschap2 caller-id-type=ip-address default-profile=l2tp-profile enabled=yes max-mru=1460 max-mtu=1460 use-ipsec=yes
/ip accounting
set enabled=yes threshold=2560
/ip accounting web-access
set accessible-via-web=yes address=192.168.1.215/32
add address=192.168.1.1/24 comment="default configuration" interface=ether2-master-local network=192.168.1.0
add address=192.168.1.1/24 interface=OfficeNet network=192.168.1.0
add address=10.0.0.1/24 interface=Guest network=10.0.0.0
/ip dhcp-client
add comment="default configuration" dhcp-options=hostname,clientid disabled=no interface=ether1-gateway
/ip dhcp-server lease
add address=192.168.1.81 comment="Insteon controller" mac-address=00:0E:F3:3C:B2:0A server=default
add address=10.0.0.0/24 dns-server=10.0.0.1,8.8.8.8 gateway=10.0.0.1 netmask=24
add address=192.168.1.0/24 comment="default configuration" dns-server=192.168.1.1,8.8.8.8 gateway=192.168.1.1 netmask=24
set allow-remote-requests=yes servers=8.8.8.8,8.8.4.4
/ip dns static
add address=192.168.1.1 name=router
add action=accept chain=input comment="default configuration" protocol=icmp
add action=accept chain=input comment="default configuration" connection-state=established,related
add action=drop chain=input comment="default configuration" in-interface=ether1-gateway
add action=fasttrack-connection chain=forward comment="default configuration" connection-state=established,related
add action=accept chain=forward comment="default configuration" connection-state=established,related
add action=drop chain=forward comment="default configuration" connection-state=invalid
add action=drop chain=forward comment="default configuration" connection-nat-state=!dstnat connection-state=new in-interface=ether1-gateway
add action=reject chain=forward connection-limit=100,32 layer7-protocol=Youtube log-prefix=porn reject-with=icmp-network-unreachable tcp-flags=""
/ip firewall mangle
add action=mark-connection chain=prerouting new-connection-mark=Stable-Ping passthrough=yes protocol=icmp
add action=mark-packet chain=prerouting connection-mark=Stable-Ping new-packet-mark=Ping-Packet passthrough=no protocol=icmp
add action=masquerade chain=srcnat comment="default configuration" out-interface=ether1-gateway
add action=masquerade chain=srcnat dst-address=192.168.1.50 dst-port=0-65000 out-interface=ether2-master-local protocol=tcp src-address=192.168.1.0/24
/ip ipsec peer
add address=0.0.0.0/0 comment=cs enc-algorithm=aes-256,aes-192,aes-128,3des,des exchange-mode=main-l2tp generate-policy=port-strict passive=yes
add disabled=yes distance=1 gateway=172.102.16.153
/ip smb shares
set [ find default=yes ] directory=/pub
/ppp aaa
set use-radius=yes
/ppp secret
add name=davep profile=pptp_profile
/system clock
set time-zone-name=America/Toronto
/tool mac-server
add interface=ether2-master-local
add interface=ether3-slave-local
add interface=ether4-slave-local
add interface=ether5-slave-local
/tool mac-server mac-winbox
[admin@MikroTik] >
My network is not working… Anyone pleaassee!! Only the guest wifi is working…
why default gateway is disabled?
Chouby
May 10, 2017, 11:17pm
9
Because I had a static IP before.. I didn’t delete it yet.. I’m DHCP from my isp now..
Chouby
May 15, 2017, 5:37pm
11
I’m trying to troubleshoot myself and I see this but I don’t understand why it is not going out on WAN…
It’s my Google Pixel pinging google DNS… but no answer
Any idea?
Just a gut feeling:
What WAN-facing device is your router connected to?
Are you sure your dhcp-client receives a public IP address?
Could it be the device somehow fell back into “home router” mode and gives out addresses in the same range (192.168.1.0/24) as you are using?
-Chris
