Capsman's antenna gain setting problem for help
The management mode of the capsman is used. In the state of the interface, the power of the AP is 30 dBm. However, in the interface of the CAP, the power of the AP is only 24 dBm.
Among them, 6dBm is the gain of the antenna. In actual use, is it necessary to change the antenna gain of the CAP to 0 to get the same state as Capsman?
If not changed, will it cause the signal received by the user terminal to be weak?
