CAPsMANv2, 5Ghz, no supported band
Hi, i am trying to configure capsman v2 on RB750r3 as central witch will manage two RBwAPG-5HacT2HnD.
2.4 Ghz works great but the problem is that 5Ghz shows as no supported band in CapsMan. This is my configuration:
/caps-man channel
add band=2ghz-b/g/n extension-channel=disabled frequency=2417 name=\
    channel-2Ghz tx-power=20 width=20
add band=5ghz-a/n/ac extension-channel=eCee \
    frequency=5785 name=channel-5Ghz width=20
add name=bridge-1
add name=bridge-2
/caps-man datapath
add bridge=bridge-2 local-forwarding=yes name=datapath-2
add bridge=bridge-1 local-forwarding=no name=datapath-1
/caps-man configuration
add channel=channel-2Ghz datapath=datapath-1 datapath.bridge=\
    bridge-1 mode=ap name=cfg1 rx-chains=0,1,2 ssid=\
    "Mikrotik" tx-chains=0,1,2
add channel=channel-5Ghz datapath=datapath-2 mode=ap name=cfg3 \
    rx-chains=0,1,2 ssid="Mikrotik 5GHZ" tx-chains=0,1,2
/caps-man security
add authentication-types=wpa-psk,wpa2-psk encryption=aes-ccm \
    group-encryption=aes-ccm name=security1 passphrase=italia015
add channel=channel-2Ghz datapath=datapath-2 datapath.bridge=\
    bridge-2 hide-ssid=no name=cfg2 rx-chains=0,1,2 security=security1 \
    ssid=Office tx-chains=0,1,2
add channel=channel-5Ghz datapath=datapath-2 mode=ap name=cfg4 \
    rx-chains=0,1,2 security=security1 ssid="Office 5ghz" tx-chains=0,1,2
RB750r3
RBwAPG-5HacT2HnD
Hi.
I think you have a configuration mismatch
5785 allow 20 Mhz channel from 5775-5795 so it couldn’t support extension channel eCee for 80 Mhz cause it will be out of band. Select disable in extension channel
add band=5ghz-a/n/ac extension-channel=disabled frequency=5785 name=channel-5Ghz width=20
Thanks for reply Gustav, tried your configuration and receive same error
What country is set for WiFi ? Is 5785 allowed for this setting ?
BTW. Power 20 for 2.4GHz … ???
I agree with BartoszP.
Check your country available channels here
https://en.wikipedia.org/wiki/List_of_WLAN_channels
And check your routerboard country channel.
The country is not set. Tried to set country that supports a band and receive same error.
I’m experiencing that same problem. Tried a few thing like setting channels and bands to different settings but none worked so far.
I’m using a hAP ac lite as CAP in conjunction with a RB2011UiAS-IN as CAPsMAN. Both on the latest Bugfix only Firmware.
Is there a fix for this?
CAPsMAN config
/caps-man channel
add band=5ghz-a control-channel-width=40mhz-turbo extension-channel=eCee frequency=5180,5260 name=channel_ac
add name=bridge-local-free protocol-mode=stp
add name=bridge-local-guest protocol-mode=stp
set [ find default-name=ether1 ] name=ether1-gateway
set [ find default-name=ether2 ] name=ether2-master-local
set [ find default-name=ether3 ] master-port=ether2-master-local name=ether3-slave-local
set [ find default-name=ether4 ] master-port=ether2-master-local name=ether4-slave-local
set [ find default-name=ether5 ] master-port=ether2-master-local name=ether5-slave-local
set [ find default-name=ether6 ] name=ether6-master-local
set [ find default-name=ether7 ] master-port=ether6-master-local name=ether7-slave-local
set [ find default-name=ether8 ] master-port=ether6-master-local name=ether8-slave-local
set [ find default-name=ether9 ] master-port=ether6-master-local name=ether9-slave-local
set [ find default-name=ether10 ] master-port=ether6-master-local name=ether10-master-local
/interface pppoe-client
add add-default-route=yes interface=ether1-gateway name=pppoe-out1
/interface sstp-client
add connect-to=212.53.151.53 disabled=no name=sstp-out1 password=H0tsp0t4All! user=7DD5063DEA10
add channel.band=2ghz-b/g/n channel.control-channel-width=20mhz country=germany datapath.bridge=bridge-local-guest name=cfg_802.11bgn \
    ssid=LAN1
add channel=channel_ac channel.band=5ghz-a channel.control-channel-width=40mhz-turbo country=germany datapath.bridge=\
    bridge-local-guest name=cfg_802.11ac ssid=LAN1
/caps-man interface
add configuration=cfg_802.11bgn disabled=no l2mtu=1600 mac-address=6C:3B:6B:1D:31:60 master-interface=none name=AP-6CBA06FC6B79-1 \
    radio-mac=6C:3B:6B:1D:31:60
# no supported band
add channel=channel_ac configuration=cfg_802.11ac disabled=no mac-address=6C:3B:6B:1D:31:5F master-interface=none name=\
    AP-6CBA06FC6B79-2 radio-mac=6C:3B:6B:1D:31:5F
/ip hotspot profile
set [ find default=yes ] dns-name=gateway.lan1.de hotspot-address=1.1.1.1 html-directory=aufbau login-by=http-pap,trial name=hsprof1 \
    nas-port-type=ethernet radius-default-domain=212.53.151.19 radius-interim-update=5m trial-uptime-limit=1d trial-uptime-reset=1h \
    use-radius=yes
add name=dhcp-network-guest ranges=10.1.0.2-10.1.0.254,10.1.1.2-10.1.1.254,10.1.2.2-10.1.2.254,10.1.3.2-10.1.3.254
add name=dhcp-network-free ranges=10.2.0.2-10.2.3.254
add address-pool=dhcp-network-guest disabled=no interface=bridge-local-guest lease-time=1d name=default-guest
add address-pool=dhcp-network-free disabled=no interface=bridge-local-free lease-time=1w name=default-free
/ip hotspot
add address-pool=dhcp-network-guest disabled=no interface=bridge-local-guest login-timeout=5m name=6C:3B:6B:BB:C2:24
/ip hotspot user profile
set [ find default=yes ] address-pool=dhcp-network-guest idle-timeout=12h keepalive-timeout=1d name=uprof1 rate-limit=\
    "1m/4m 2m/8m 512k/2m 120/120 6 512k/2m" shared-users=3
add address-list=js_user address-pool=dhcp-network-guest idle-timeout=1h keepalive-timeout=2h name=js rate-limit=\
    "256k/786k 512k/1m 256k/786k 120/120 6 256k/786k" shared-users=2
add address-pool=dhcp-network-guest idle-timeout=15m keepalive-timeout=15m name=guthaben rate-limit=\
    "1m/4m 2m/8m 512k/2m 120/120 6 512k/2m" shared-users=2
add address-pool=dhcp-network-guest idle-timeout=12h keepalive-timeout=1d name=tagung rate-limit=\
    "1m/4m 2m/8m 512k/2m 120/120 6 512k/2m" shared-users=100
/ppp profile
add bridge=bridge-local-free change-tcp-mss=yes name=default-network-free use-encryption=yes
add bridge=bridge-local-guest change-tcp-mss=yes name=default-network-guest use-encryption=yes
/caps-man manager
set enabled=yes
/caps-man provisioning
add action=create-enabled master-configuration=cfg_802.11bgn name-format=prefix-identity name-prefix=AP
add bridge=bridge-local-guest interface=ether2-master-local
add bridge=bridge-local-free interface=ether6-master-local
/interface sstp-server server
set enabled=yes
add address=10.0.0.1/24 comment=mgmt_network interface=bridge-local-guest network=10.0.0.0
add address=10.1.0.1/22 comment=guest_network interface=bridge-local-guest network=10.1.0.0
add address=10.2.0.1/22 comment=free_network interface=bridge-local-free network=10.2.0.0
/ip dhcp-client
add dhcp-options=hostname,clientid disabled=no interface=ether1-gateway use-peer-dns=no
add address=10.0.0.0/22 comment=mgmt_network dns-server=8.8.8.8,8.8.4.4 gateway=10.0.0.1 netmask=22
add address=10.1.0.0/22 comment=guest_network dns-server=8.8.8.8,8.8.4.4 gateway=10.1.0.1 netmask=32
add address=10.2.0.0/22 comment=free_network dns-server=8.8.8.8,8.8.4.4 gateway=10.2.0.1 netmask=22
set servers=8.8.8.8,8.8.4.4
/ppp secret
add name=6CBA06FC6B79-guest-network password=secret profile=default-network-guest service=sstp
add name=6CBA06FC6B79-free-network password=secret profile=default-network-free service=sstp
CAP config
add fast-forward=no name=bridge-local
add fast-forward=no name=bridge-local-free
set [ find default-name=ether3 ] master-port=ether2-master-local name=\
    ether3-slave-local
set [ find default-name=ether4 ] master-port=ether2-master-local name=\
    ether4-slave-local
set [ find default-name=ether5 ] name=ether5-master-local
/interface wireless
# managed by CAPsMAN
# channel: 2422/20-Ce/gn(20dBm), SSID: LAN1, CAPsMAN forwarding
set [ find default-name=wlan1 ] ssid=MikroTik
set [ find default-name=wlan2 ] ssid=MikroTik
/ip hotspot profile
/ppp profile
add bridge=bridge-local-free change-tcp-mss=yes name=default-network-free \
    use-encryption=yes
set *FFFFFFFE bridge=bridge-local
add connect-to=10.0.0.1 disabled=no mrru=1600 name=sstp-out1-guest-ntwrk \
    password=secret profile=default-encryption user=\
add connect-to=10.0.0.1 disabled=no mrru=1600 name=sstp-out2-free-ntwrk \
    password=secret profile=default-network-free user=\
add bridge=bridge-local interface=ether2-master-local
add bridge=bridge-local interface=wlan1
add bridge=bridge-local interface=wlan2
add bridge=bridge-local-free interface=ether5-master-local
/interface wireless cap
set caps-man-addresses=10.0.0.1 enabled=yes interfaces=wlan1,wlan2
add address=10.0.0.103/24 interface=ether1-gateway network=10.0.0.0
add distance=1 gateway=10.0.0.1
/ip service
set telnet disabled=yes
set ftp disabled=yes
set api disabled=yes
set api-ssl disabled=yes
/system clock
/system identity
set name=6CBA06FC6B79
/system ntp client
set enabled=yes primary-ntp=134.130.4.17 secondary-ntp=134.130.5.17
/system package update
set channel=bugfix
