I get lots of “bridge port received packet with own address as source address, probably loop.” interface,warning in log. This happens when a WiFI client switches between APs with same SSID in a building. Sometimes this brings the connection down (probably rstp) for long enough that CAP timeouts connection to CAPSMANv2, disconnects and looses all of its clients which I find very annoying. Any suggestions how to avoid this? I would still like to use rstp if possible.
For now I have enabled local forwarding on all APs and the problem is gone … with capsman forwarding I could not get ride of those loop warnings. I tried bridge horizon 1, stp isolation … nothing worked.
could you email support@mikrotik.com and include a support output file from the CAPsMAN when the problem is happening?
Also how are the CAPs connecting to the CAPsMAN - via IP or via MAC?
I currently do not dare to test because customers are still quite pissed off … will do so after few weeks pass … giving it a thought about my network I think proxy-arp bridge setting could be the culprit but I need it because of my ipsec/l2tp setup for roadwarriors so local forwarding might be the only option for my setup.
