CAPsMANv2 Scanlist - MISSING?
Currently getting to grips with CAPsMAN2.
I’ve been experimenting with channel allocation and setting them to “auto” / blank.
At the moment the auto frequency option selects any channel (1 to 11) and this can lead to AP channel overlap (using 20 MHz channels). It appears as though as long as there is no overlap/interference with the 5 MHz centralish channel it will allocate the next one along.
Therefore in the 2GHz frequency range I only want the auto frequency to select from channels 1, 6 and 11.
From memory I need to create a scan-list that includes 2412, 2437, 2462. I expect this to prevent the overlap problem - to an extent.
However in CAPsMAN2 I don’t seem to be able to choose scan list is an option?
Is this not a feature? Perhaps I’m looking at it from the wrong angle?
Can anyone help?
Regards
Aidan
