captive portal/2nd SSID
hi all
We have a config which has a captive portal that goes on to our mikrotik 951 routerboard.
What we are looking at doing is leaving this as is but adding a 2nd SSID .
the problem being when we install this config on the mikrotik it is managed by capsman and i cant work out how to add a second SSID when capsman is enabled.
i can add a multiple SSID’s when i disable capsman but then we cant use the captive portal
tried loads of different guides to no avail
any help greatly appreciated
thank you in advance
mike
Hi.
You can achieve this using slave interface to master provisioned physical wlan interface.
Check this out to have virtual AP (2nd SSID)
https://mum.mikrotik.com/presentations/TR14/mani.pdf
It really wokrs!
