Can someone provide me the captive portal files
not only the login.html but the whole folder / directory structure
i accidentally deleted the files on my routerboard
any will do (default or modified)
Just use the command:
/ip hotspot reset-html 0
You might need to replace the 0 with the number of your hotspot server instance, but if you only have one, it should be 0.
Thanks ![]()
