Captive Portal + OAuth 2.0 Client ID
Greetings. I’ve been trying to implement Captive Portal + OAuth 2.0 Client ID for a while now. I’ve used valid SSL, simplified the default variables, and used the appropriate script to only interact between MikroTik and the Google platform. Firewall filters and dynamic NATs slightly disrupt the synchronization between the MikroTik server and the Google platform. I’ve implemented this with the intermediation of an external server as the means of interaction with the Google platform, given that both are external servers with greater benefits for using HTTPS and APIs, but there are limitations in MikroTik that still don’t allow me to achieve this. Do you know of any functional use cases?
