Captive portal with remote authentication
I want to run a captive portal for clients. Portal will be running on my server (PHP site with MySQL for users and profiles) and question is, if it is possible for Mikrotik to be able to work with this remote authentication website. So router will redirect to my server and once user is authenticated, router permits web access.
Thank you very much,
Martin
You can use UserManager and configure Radius to do it.
Hi, Maybe so, but I was asking if it is possible for MikroTiks routers to work in Hotspot mode with remote authentication server(site) - I need to use user login information for other purposes (sending marketing stuff, etc.) And this one auth. site is supposed to work for more Mikrotiks (hotspots).
Thanks,
Martin.
