Card Testing!
What I’m wondering is why MikroTik can’t have a package that can be installed on their higher end boards that can test MikroTik cards. That way if you have a bad card there would be an easy and reliable way to detect card issues?
I think it should be done during manufacturing =)
what do you mean by “card”, a wireless miniPCI card? what do you mean by “bad”? RouterOS is only software, you need hardware test machine to truly identify a bad card. RouterOS will either be able to communicate it, or not, nothing else.
