I have run across a problem of late and am stumped for a solution.
I have noticed that certain cards are suddenly losing 10-20dB signal for no apparent reason. The cards include the Mikrotik R52 (abg), Senao NMP-8602 (abg) and Senao NMP-3602 (bg).
The information I have is:
- The cards are at various sites spread across the city and are not always in the same area.
- The signal strength drops to -91 to -94 from a range of -70 to -80.
- Some sites do not have the routerboard earthed. (earthing the board in some, but not all, cases prevents the problem from re-occurring)
- Some sites do have the routerboard earthed.
- The problem re-occurs at the same sites.
- The power feed to the sites vary. Some are municipal AC, others are UPS and others battery.
- One site changed the card to a CM9 which lasted longer, but also lost signal.
- A Senao SL-5354MP has worked at a problematic site for 3 months. The routerboard was replaced recently and the new R52 card lost signal overnight.
- The cards mostly (but not always) lose signal overnight.
- The weather does not seem to be a factor as this has happened in good or bad weather.
- All cards are Atheros based chipsets.
- Time between installation of card and loss of signal varies from 3 weeks to 5 minutes.
Does anyone have any ideas?
Regards,
Wispy
