Is there any way to insert a carriage return in notes? I am trying to list out the port states of each switch with their description. Right now the only way to make it readable is to enter a separate note for each port. I would like to keep it to one note so i can use a simple text template for each switch.
Here is what the note looks like. If i just paste this all into one note they all run together, otherwise i have to create a note for each port to get them to show up line by line. The switches with 48 ports are a real bear.
1 [oid(“1.3.6.1.2.1.2.2.1.7.1”)] [oid(“1.3.6.1.2.1.2.2.1.8.1”)]***
2 [oid(“1.3.6.1.2.1.2.2.1.7.2”)] [oid(“1.3.6.1.2.1.2.2.1.8.2”)]MW-RESERVED
3 [oid(“1.3.6.1.2.1.2.2.1.7.3”)] [oid(“1.3.6.1.2.1.2.2.1.8.3”)]***
4 [oid(“1.3.6.1.2.1.2.2.1.7.4”)] [oid(“1.3.6.1.2.1.2.2.1.8.4”)]MW-RESERVED
5 [oid(“1.3.6.1.2.1.2.2.1.7.5”)] [oid(“1.3.6.1.2.1.2.2.1.8.5”)]***
6 [oid(“1.3.6.1.2.1.2.2.1.7.6”)] [oid(“1.3.6.1.2.1.2.2.1.8.6”)]MW-RESERVED
7 [oid(“1.3.6.1.2.1.2.2.1.7.7”)] [oid(“1.3.6.1.2.1.2.2.1.8.7”)]-RESERVED
8 [oid(“1.3.6.1.2.1.2.2.1.7.8”)] [oid(“1.3.6.1.2.1.2.2.1.8.8”)]MW-RESERVED
9 [oid(“1.3.6.1.2.1.2.2.1.7.9”)] [oid(“1.3.6.1.2.1.2.2.1.8.9”)]Omnitronix
10 [oid(“1.3.6.1.2.1.2.2.1.7.10”)] [oid(“1.3.6.1.2.1.2.2.1.8.10”)]MW-RESERVED
11 [oid(“1.3.6.1.2.1.2.2.1.7.11”)] [oid(“1.3.6.1.2.1.2.2.1.8.11”)]PowerSupply
12 [oid(“1.3.6.1.2.1.2.2.1.7.12”)] [oid(“1.3.6.1.2.1.2.2.1.8.12”)]MW-RESERVED
13 [oid(“1.3.6.1.2.1.2.2.1.7.13”)] [oid(“1.3.6.1.2.1.2.2.1.8.13”)]-RESERVED
14 [oid(“1.3.6.1.2.1.2.2.1.7.14”)] [oid(“1.3.6.1.2.1.2.2.1.8.14”)]MW-RESERVED
15 [oid(“1.3.6.1.2.1.2.2.1.7.15”)] [oid(“1.3.6.1.2.1.2.2.1.8.15”)]Digi-Modem
16 [oid(“1.3.6.1.2.1.2.2.1.7.16”)] [oid(“1.3.6.1.2.1.2.2.1.8.16”)]-RESERVED
17 [oid(“1.3.6.1.2.1.2.2.1.7.17”)] [oid(“1.3.6.1.2.1.2.2.1.8.17”)]TAS-RESERVED
18 [oid(“1.3.6.1.2.1.2.2.1.7.18”)] [oid(“1.3.6.1.2.1.2.2.1.8.18”)]OB-DUL006-DW
19 [oid(“1.3.6.1.2.1.2.2.1.7.19”)] [oid(“1.3.6.1.2.1.2.2.1.8.19”)]OB-DUL999-DW
20 [oid(“1.3.6.1.2.1.2.2.1.7.20”)] [oid(“1.3.6.1.2.1.2.2.1.8.20”)]OB-RESERVED
21 [oid(“1.3.6.1.2.1.2.2.1.7.21”)] [oid(“1.3.6.1.2.1.2.2.1.8.21”)]OB-RESERVED
22 [oid(“1.3.6.1.2.1.2.2.1.7.22”)] [oid(“1.3.6.1.2.1.2.2.1.8.22”)]{{-7}}
23 [oid(“1.3.6.1.2.1.2.2.1.7.23”)] [oid(“1.3.6.1.2.1.2.2.1.8.23”)]TechAccess
24 [oid(“1.3.6.1.2.1.2.2.1.7.24”)] [oid(“1.3.6.1.2.1.2.2.1.8.24”)]Inter Switc
25 [oid(“1.3.6.1.2.1.2.2.1.7.25”)] [oid(“1.3.6.1.2.1.2.2.1.8.25”)]MW-DUL999-DW
26 [oid(“1.3.6.1.2.1.2.2.1.7.26”)] [oid(“1.3.6.1.2.1.2.2.1.8.26”)]MW-DUL006-DW
