Cat5e Cable
Hello All,
I’m installing a SXT LTE6 outside. What cable would you recommend. Would this cable be ok? (Link below) Or any other recommendations for which cable I need to use.
https://www.kenable.co.uk/en/networking/cables-patch-and-reels/network-cables-reels/8541-external-shielded-cat5e-outdoor-copper-ethernet-cable-ftp-reel-50m-008541-5055383485413.html
It is more than enough, i am using a regular 5e UTP for years outside now, and it is still holding strong.
Of course if you think you will mount something more powerful in the future, it aint bad to invest a little bit more in CAT6/7 so you could use the all more used 2.5/5/10 gb ethernet.
