Categorizing OpenVPN users to access specific servers
Hi All,
I want to group remote OpenVPN users so that each group can only access certain server(s) and not see the rest of the servers. How can I do this in Mikrotik? Please note that OpenVPN settings are currently set up and all remote users can access all servers.
Can someone help me with this?
Use different PPP Profiles for different users.
And add to each profile the address list (or interface list, whatever suits you better) where the user using this profile will be added.
Or you can even use separate firewall chains for each profile defined in incoming-filter and outgoin-filter in profile settings.
thank you so much xvo !
The problem solved. your suggestion helpt me.
Best Regards
You are welcome! :slight_smile:
