Hi
I am starting a new thread from
CCR 1036. High load loses packets. Big problem. as the OP seems to have solved their problem.
I am having some issue pushing 1 TCP stream pas 1Gb/s through these devices.
env
2 x 8024F 10G switches stacked
2 x cc1036 cross connect to 2 10G ports / device. This is done as a LACP. I also use vrrp
/interface bonding
add mode=802.3ad mtu=9000 name=bond0 slaves=sfp-plus1,sfp-plus2 transmit-hash-policy=layer-2-and-3
interface port-channel X
description "rtr lag"
hashing-mode 6
switchport mode trunk
mtu 9216
exit
for sfp-plus1&2 I have l2mtu at 9216
I have previously used 3 test box's with iperf. I use ESX 5.5i and vmxnet3 with centos 6.5
2 clients and 1 server.
I have not been able to get above 1Gb/s for a single tcp stream, I can sometimes push UDP up to 6.5Gb/s . I have been able to push tcp by doing multiple streams.
I am now just testing with 2 VM
client to server same VLAN.... 10Gb's tcp and udp
if I route through the CCR, I get crappy performance. I have monitored interfaces and can see the packets are getting distributed.
I am at a loss, this it no where near the capacity talked about on the spec sheet
from previous post
so I have 3 sites all attached by 10G SFP+ (fibre runs)
site A
test box is centos 6.5 vm vmnext3 -> dell 8024F 10G switch ... doing routing as well -> 10G SFP to Site C -> dell 8132F switch router -> another test box centos 6.5 vm vmnext3
Site O
test box centos 6.5 vm vmnext3 -> 10G dell 8024F switch (switching only) -> CCR1036-8G-2S+ (actually 2 in vrrp mode). -> switch (same) -> 10G SFP to site A or C [stp determines] @ site C -> dell 8132F switch router -> another test box centos 6.5 vm vmnext3 (only 1 test server at site C)
the CCR1036-8G-2S+ are connected via 2 SFP+ 10G cables to the 8024F's I have 10G link speed. I have set them up as LACP and there are vlan trunked.
the underlying trunk is 9216 l2mtu but most of the vlans are 1500 mtu. 1 vlan is 9k but it is not traverse in these tests
the outbound hash is l2-l3 this makes it use different slave ports for inbound and outbound for the test
i use iperf
site C box is iperf server
iperf -s <<< tcp test
iperf -s -u -b 20480M -U <<< singe thread udp
clients
iperf -c 10.33.95.21 -u -b 20480M -U -i 2 -t 60 << udp
iperf -c 10.33.95.21 -t 60 << tcp
I have tuned the linux box's 10000 txqueue length sack and window size (3M)
site a -> site c 8-9Gb/s
site c -> site c 9Gb/s .... different ip network so its routed through the dell router/switch
site O -> site c 800Mb/s is the max I can get with tcp
site O -> site c 4-6G/b if I use UDP
if i setup a dual test its around 5G/b
I think my udp packets are not 1-1K... not sure how to set that right now and I am not sure it tests that...
just thought I would add my 2c.
My plan had been to remove the routing off the dell switchs. they have the functions but they are not very good at a lot of things.
I still have to investigate weather is the bonded SFPs...
edit:
I have firewall rules set in place on most interfaces
edit:
ran some TCP tests in parrallel from the same machine 10 streams got me 1.9G
20 tcp streams got me to 6.29Gb/s
again i think with full packets ~1500
edit..
tried the inbuild bandwithtest.... most I could get out of it was 500Mb/s ...
I bought 2 of these... going to be very disappointed if they can't route at close to 10Gb/s ...
