Hi all.
In my registratin table stats I can see:
- tx-signal-strength=-61dBm
- tx-ccq=100%
- rx-ccq=100%
BUT
frames=154637,420371
AND
hw-frames=288097,860404267
It seems that hw-frames-r/frames-rx > 6000!
If it retries so much, how the ccq could be 100% ?
[admin@mycpe] > /interface wireless registration-table print stats
0 interface=wlan1 radio-name=“acquapartita_BS” mac-address=00:0B:6B:57:F0:B5
ap=yes wds=no rx-rate=54Mbps tx-rate=54Mbps packets=170094,437515
bytes=15746710,218511804 frames=154637,420371
frame-bytes=15230568,216578622 hw-frames=288097,860404267
hw-frame-bytes=27918899,1141067331 uptime=5d20h13m49s last-activity=20ms
signal-strength=-58dBm@6Mbps signal-to-noise=44dB
strength-at-rates=-58dBm@6Mbps 0s,-58dBm@9Mbps 5d13h46m34s740ms,-
58dBm@12Mbps 5d13h46m23s20ms,-58dBm@18Mbps
5d13h45m58s830ms,-59dBm@24Mbps 5d13h45m33s990ms,-
61dBm@36Mbps 5d13h44m58s660ms,-62dBm@48Mbps 24m56s390ms,-
60dBm@54Mbps 20ms
tx-signal-strength=-61dBm tx-ccq=100% rx-ccq=100% p-throughput=40853
nstreme=yes framing-mode=exact-size framing-limit=3600
routeros-version=“2.9.38” 802.1x-port-enabled=yes
authentication-type=wpa-psk encryption=aes-ccm group-encryption=aes-ccm
compression=no
