CCQ Drop
Good day
I am having big difficulty with my high sites. Our whole network is run off Mikrotik devices and all our clients have signal between -40 to -65db where CCQ’s and throughput shows no problems until data is tried to be transferred or received threw antenna and CCQ’s will drop from 80/90% to below 12%. I have run multiple spectrum analysis even on superchannel. but no results. we use mostly Basebox 5 and NetMetals on our sectors. we even tried moving from 120 degrees sectors to 45 degrees sectors to minimize interference but no luck infact is worse. we have discovered aswell that most sectors begins to cause the problem when exceeding over 12 clients on the sectors which seems like a a overload is causing issue but 12 clients is not that much. Sectors are on nstreme which shows best results but still problems. Please can some one give advice, tips or any suggestions on what i can try. playing frequency is a no go as it does not work.
Greetings
ShadowLurker85
IT Technician
