CCQ Questions
How much % in CCQ should i expect in a link of about 6km distance? at the moment i have :
Signal strenght : -69dbm
Tx signal strenght : -69dbm
SNR : 33db
Tx/Rx CCQ : 55/64 %
clear line of sight
2,4GHz 24dbi antennas and LMR-400 ~6m cable both sides!
wht is the antenna type being used?
Our 6 km link with 22 dbi antenna n 5.8 ghz frq gives us 97/98% ccQ
about 100/100
yeah, i knew that it has to be 100/100. both sides have pacific wireless Grid 24dbi antennas. i’ll take a look tomorrow!
which is the lowest acceptable CCQ value for a stable link? maybe 80% ? and what can somebody do to optimize the link, additional to allignment?
if there is high interference in ur area u will rarely find 100/100 . u can check by changing antenna polarity and implementing rts/cts for AP and client.
