I read some posts about this but they were old and seemed to refer to some older versions of RouterOS with issues. I just want to know:
What is the approximate max throughput of IPSec tunnel on the CCR-1009-7G with HW acceleration?
Does HW acceleration work properly with current versions of RouterOS, any caveats?
Do IP firewall mangle rules such as MSS clamp and connection marks affect/disable the HW acceleration? If so, how fast can it go with CPU alone?
What’s the max throughput each single tunnel/connection can reach, if it’s different from overall capacity due to multi-core design?
Your advice would be greatly appreciated!
