CCR 1009 and SD card
Hello
We have a lot of already installed routers CCR 1009
And now we have bought SD cards for this devices
It was microSDHC UHS-I SAMSUNG EVO PLUS 32 Gb
CCR 1009 does not see this memory card
command /file print returns empty result
We rebooted test router, flash different versions and formated card in other file systems. It had no result :frowning:
But if SD card connect via USB cardreader and USB OTG cable it was working correctly.
Had anysome solved problem of compability of CCR and Samsung card ? Help please
Same issue here, tried about 5 different SD Cards from different vendors and different Capacity but none of them works. Also tried to remove all partitions + partition table. But the CCR1009 is not able to detect them. Tested with RouterOS 7.1.1.
There is an open bug with sd cards on the ccr1009 models (at least) on 7.x
Hey everybody,
are any news about this Problem?
I have this issue on a CCR1009, reported in SUP-81653.
Looks like this is known to Mikrotik, but they did not bother to fix it, yet.
Same probleme in 7.4 …
Just wait until you hit the performance issues, once it gets discovered…
Same problem on 7.5. Hope that someone will take care of that issue.
The same here with CCR1009-7G-1C-1S+. The last ROS which can see the SD card is 6.49.7. Nothing with 7.x.x up to 7.7-beta8. I hope MikroTik will not decided to cancel support for SD card reader at all, even though the usability of SD card on CCR1009 or CCR1036 (maybe all CCR) is very limited due to very slow speed referred it this thread http://forum.mikrotik.com/t/what-speed-of-usd-card-reader-is-used-in-the-routerboard-products/154041/1
Mikrotik Support gave me an answer..
RB760iGS and RB750Gr3:
Upload to microSD ~51.8Mb/s
Download from microSD ~54.7Mb/s
CCR1009-8G-1S-1S+
Upload to microSD: ~2.8Mb/s
Download from microSD: ~1.9Mb/s
Why?
What is your plan for the cards?
I don’t have an answer for you though, my main CCR is still on v6.
It would be a shame that Mikrotik cut a function that released at the moment we bought the router for not fixing a bug. It’s just a shame that the bug is yet to fix.
It’s so disappointing that it isn’t fixed even in the latest 7.7 stable version. I wonder whether Mikrotik knows it or they simply don’t want to fix it.
The problem still exists at RouterOS 7.8 stable.
When could we expect a fix? Should we report this bug at support again?
I received a message from support:
Our bug tracker reports, that your issue has been fixed. This means that in the upcoming days, we plan to release a RouterOS update with this fix. Make sure to upgrade to the next release when it comes out soon. To be sure this specific fix is included, read the changelog when the next version comes out. If your issue is not mentioned, it might mean it will be in the next release.
So I guess chances are that the fix will come with 7.10beta…
That said… My need for this has gone. As I store temporary files only using tmpfs is fine for me…
Looks like this was fixed in v7.10 but I can’t get it to work on my CCR 1009-8G-1S-1S+ on 7.10.2 with a standard 32GB SD card. Anyone else able to get it working now?
