CCR 1009 does not initialize. no netinstall
CCR keeps restarting, I can’t start netinstall. I can’t use netinstall using RS232 serial cable
Press any key within 2 seconds to enter setup..
loading kernel… OK
setting up elf image… OK
jumping to kernel code
Could not mount ubifs filesystem: Invalid argument
opendir: No such file or directory
ERROR: no system package found!
Kernel panic - not syncing: Attempted to kill init!
Starting stack dump of tid 1, pid 1 (init) on cpu 8 at cycle 11907065189
frame 0: 0xfffffff70051fc00 dump_stack+0x0/0x20 (sp 0xfffffe007eedfc08)
frame 1: 0xfffffff700518b98 panic+0x168/0x398 (sp 0xfffffe007eedfc08)
frame 2: 0xfffffff700053a78 do_exit+0x1c8/0xd48 (sp 0xfffffe007eedfcb0)
frame 3: 0xfffffff700054740 do_group_exit+0xf0/0x1e8 (sp 0xfffffe007eedfd78)
frame 4: 0xfffffff700054858 __wake_up_parent+0x0/0x18 (sp 0xfffffe007eedfdb0)
frame 5: 0xfffffff700520958 handle_syscall+0x210/0x2d0 (sp 0xfffffe007eedfdc0)
frame 6: 0x8e648 0x8e648 (sp 0x7fdbf980)
Stack dump complete
Rebooting in 1 seconds..Resetting chip and restarting.
I think you should press CTRL + E to enter setup…
And yes i do remember correctly…
https://wiki.mikrotik.com/wiki/Manual:Etherboot
So, maybe you missed that step ?
I have same problem with ccr 1009
Can you help me?
I have the same issue, same error message on the serial console.
This started after I tried to upgrade the firmware from within winbox.
Did you ever solve it?
Try running backup routerboot (there usually is extra button or pad on PCB to force loading of backup routerboot).
It’s possible this is bug in current version of routerboot.
If you press the reset button before applying power to the device then the backup bootloader will load…
