CCR-1016 connection loss on outside line
Hi guys,
I’v got this new cloud core router 1016, just opened the box, connected by a pc to it on 192.168.88.1.
configured the external interface to a public IP, I have a good connection. but this external connection is lost every 5-10 minutes, for about 5-10 seconds.
I have 2 pings runing, one from my pc to 192.168.88.1
and second is to the public IP.
the local 192.168.88.1 keeps pinging 100%
but the external loses connection every 5-10 minutes.
I have updated to latest software, and to latest firmware. still same problem.
anybody had same experiance ? if yes, did you find a solution ?
thanks in advance.
After reset problem is solved.
thanks anyway.
