I installed ccr 1016 replacing 2011. With 2 bridges. Bridge 1 ether 1 to 6 and bridge2 ether 8-10. Extensive drops on some ports and 2 ports (6 and 10) were unable to communicate with the devices.I’d to use switches to run the network. Neighbour discovery adds every interface like pppoe users, making list unreadable. Sent the support file to the support.
Please send your request to support@mikrotik.com, there is no e-mail from you at the moment. We will research your issue.
Though I have checked mine CCR that works as bridge/switch, /ip neighbor table looks correct on them.
support.rif has already been sent and support has reverted on the same.
had u tested neighbours with pppoe server on ?
shall i give u read only account in mail ?
just received rc9 from mikrotik and the problem is resolved.
Deleted because not related.
Is this corrected or is it supposed to show EVERY interface? As stated, this makes the list difficult to read. I can filter list to not contain PPP in interface name as a work around, but would prefer not to see 400 PPPoE interfaces by default.
Situation exixts in RC11 on X86.
