CCR 1036 16Gb RAM and connection tracking
I have model: CCR1036-12G-4S.
Installed version: 6.0rc9
I replaced default 4Gb ram with 16Gb (two 8Gb modules) and in Winbox I can see that I have 15.9 GiB, but in console I see only
[ard@z3k-router] > /system resource print
             uptime: 2d20h6m48s
            version: 6.0rc9
         build-time: Feb/08/2013 08:15:34
        free-memory: 3534.3MiB
       total-memory: 3957.0MiB
                cpu: tilegx
          cpu-count: 36
      cpu-frequency: 1000MHz
           cpu-load: 0%
     free-hdd-space: 903.5MiB
    total-hdd-space: 1024.0MiB
  architecture-name: tile
         board-name: CCR1036-12G-4S
           platform: MikroTik
Why do I see different information in winbox and in terminal (trough ssh)? And how to correct this?
Next in connection tracking system I see only 512K max-entries (the same for 4Gb ram and for 16Gb):
[ard@z3k-router] > ip firewall connection tracking print
                   enabled: auto
      tcp-syn-sent-timeout: 5s
  tcp-syn-received-timeout: 5s
   tcp-established-timeout: 1d
      tcp-fin-wait-timeout: 10s
    tcp-close-wait-timeout: 10s
      tcp-last-ack-timeout: 10s
     tcp-time-wait-timeout: 10s
         tcp-close-timeout: 10s
               udp-timeout: 10s
        udp-stream-timeout: 3m
              icmp-timeout: 10s
           generic-timeout: 10m
               max-entries: 524288
             total-entries: 0
[ard@z3k-router] >
In some situation such amount is not enough. Especially during DOS attacks with spoofed IP address going throug the router. Looking at previous experience It would be nice to increase this value at least 5 times. This vaue is read-only so I simply can’t change it.
I will definetely try latest os version, but don’t see anything related to my issues in changelog.
Any help is appreciated.
Regards Dennis M.
Today I looked at RB1200 and found that it has the same connection-tracking limi of “max-entries: 524288”
[ard@****k] > ip firewall connection tracking print
                   enabled: yes
               udp-timeout: 10s
              icmp-timeout: 10s
             tcp-syncookie: no
               max-entries: 524288
             total-entries: 3812
[ard@****k] > system resource print
                   uptime: 8w2d3h56m55s
                  version: 5.5
              free-memory: 478496KiB
             total-memory: 516560KiB
                      cpu: 460GT
                cpu-count: 1
            cpu-frequency: 999MHz
                 cpu-load: 41%
           free-hdd-space: 30580KiB
          total-hdd-space: 61440KiB
  write-sect-since-reboot: 60975
         write-sect-total: 60975
               bad-blocks: 0%
        architecture-name: powerpc
               board-name: RB1200
                 platform: MikroTik
[ard@****k] >
This seems to be some common limit for the devices with 512Mb and above memory installed. Also update to the latest beta didn’t solve the issue. Is there any way to increase this limit?
Regards Dennis M.
Probably no, it looks like hard-coded value (512k).
See my post http://forum.mikrotik.com/t/connection-tracking-max-entries-property/59005/1
Regards,
there was a bug in winbox, it is fixed in latest v6.0rc12 build.
you mean, the bug was in CLI? %)
yes of course :slight_smile: 16GB is the correct one
and what about conntrack max-entries?
this number doesn’t automatically increase just by adding RAM, it increases based on remaining RAM, when you use most of the entries given in the number. So if your default max is 500000 with 4GB, it will be also 500000 with 16GB until you use 500000, then it will increase based on free RAM
Thanks Normis, it’s good to know that hard-coded limit doesn’t exists.
Regards,
