Has anyone noticed any limitation on the bonding interface?
I have 4 gig ports bonded on a CCR1036 connected to another CCR1036.
I use mode ‘balance rr’.
If iI do bandwidth test (UDP, 1500bytes) I can see all ports being used, but the pps will never go above 140000 limiting the total bandwidth to ~1.6Gbit instead of reaching a full 4gbit.
By removing or adding more interfaces to the bonding interface doesn’t change the limit of 140kpps.
With a single gbit port it can reach 80-90kpps. So in theory -at least- it should be able to reach ~360kkps with 4gbit interfaces bonded.
Is this a pps limitation of the bonding interface or the bandwidth test tool?
At the moment I don’t have physical access to those CCRs and cannot put some forwarded traffic to check if this limitation is on the btest tool.
Has anyone else encountered this behavior?
